https://www.amazon.com/Hydroseal-Fitting-Jetstream-Pieces-Schedule/dp/B08FFT1TL3/ref=sr_1_4?crid=1J3EXFOG2P2ST&keywords=1%2Bin%2Bpv c%2Bunion&qid=1692234790&sprefix=1%2Bin%2Bpvc%2Bun ion%2Caps%2C282&sr=8-4&th=1 |
http://forums.pelicanparts.com/uploa...1692741214.jpg The tiny blacked-out rectangle in the lower left is the little box with the incoming shutoff valve in it. The area shaded with dashed diagonal lines is the driveway and walkway. The areas with the diagonal lines are plantings that go relatively undisturbed for years (no tilling). The areas with cross-hatched diagonal lines are ones I like to till each spring in preparation for planting vegetables. Everywhere else is grass I don't care about. Very possibly, there will be more plantings in the front. Lois Lane can't stop planting things. Quote:
http://forums.pelicanparts.com/uploa...1692741544.jpg http://forums.pelicanparts.com/uploa...1692741544.jpg http://forums.pelicanparts.com/uploa...1692741544.jpg This all appears to be glued-together plastic pipe. Quote:
Sure, I could dig an inspection hole but I think I'll start that when I am actually going to "do this thing." At this point, I hope to learn more about what branches and bibs will be needed. Quote:
Hi Jim - all that information helps a lot......will get back to you soon!
Baz, there is NO hurry WHATSOEVER. This project will not happen soon.
Hi Jim....
Could you please verify for me exactly where your two existing hose bibs are? I looked at your photos and read your comments but am still not sure where they are. Thanks! |
Sorry for the delay, and now I will be gone for 11 days or more. In the meantime, this image shows two bibs in blue-ish ink with circled X's. Unfortunately, the only planting area reachable from a bit without hoses running everywhere is the tomato patch next to the upper bib on the South side of the house (I should have turned the images over, since the top of the page faces south instead of north.
Anyway, I think I probably need to run underground lines to the other planting areas. And also, it may be a good idea for me to plan the development of the front yard area which is on the left. This area is agriculturally undeveloped and I think Lois Lane is going to want stuff there. Largely plants as opposed to lawn. Perhaps I can do this in phases. http://forums.pelicanparts.com/uploa...1693507357.jpg |
To your comment about future developments....it always helps to have an idea of how you envision the use of your property. Not always needed in detail but an overall concept would help. Cheers! Baz |
i sure appreciate this, Baz. I'll talk with Lois about planning for the front yard.
| All times are GMT -8. The time now is 10:25 PM. |
