-   -   LED Driver Help (http://forums.pelicanparts.com/off-topic-discussions/1144987-led-driver-help.html)
NY65912 08-18-2023 01:04 PM
LED Driver Help
One of the outside LED lights on our Office/Shop went bad. The driver for the light is NLA.
It is a Towin FS50W-42C1200 Class 2 (wet) driver.
Input 100-277VAC 50/60Hz
Output 1200mA / 26-42 VDC
Uout max 44VDC P out 50.4W max
There are a ton of them and I know zip about these.
I am comparing the specs but nothing seems to match up.
Any help is greatly appreciated.
TIA
NY65912 08-18-2023 01:06 PM
http://forums.pelicanparts.com/uploa...1692389135.jpg
stevej37 08-18-2023 01:39 PM
I know nothing about them...but have you tried calling Towin?
aschen 08-18-2023 01:55 PM
no expertise in LED lighting, some expertise in EE. A quick search leads me to this guy:
https://www.trcelectronics.com/View/Roal/RCL050-1200A.shtml
look 171 08-18-2023 04:38 PM
Does it need to be water proof?
https://www.hafele.com/us/en/product/dimmable-driver-e-series-12-v/P-00863707/#SearchParameter=&@QueryTerm=led+driver&Category=R NsKAOsF1dAAAAF.Gs7iJvmA&@P.FF.followSearch=9860&Pa geNumber=1&OriginalPageSize=12&PageSize=12&Positio n=8&OrigPos=17&ProductListSize=31&PDP=true
Based on their number, you should be able to fine a vendor or buy on line. They wouldn't sell to you direct
Zeke 08-18-2023 05:32 PM
I have a bad LED fixture. Cost less than 20 new. The driver was 60. Didn't fix it so it's the LED board. Can't find the same trim. Done with china junk.
look 171 08-18-2023 06:06 PM
What are you looking for?
NY65912 08-19-2023 07:06 AM
Thanks for the suggestions. Yes, needs to be waterproof. I have been on the TRC website for 2 days trying to figure out which I need.
Cheers
Zeke 08-19-2023 12:07 PM
http://forums.pelicanparts.com/uploa...1692472016.JPG
3000K dimmable, plugs into can with a wago like or automotive like connection.
Pazuzu 08-19-2023 02:06 PM
Good replacement:
https://ballastshop.com/espt050w-1200-42-z1-erp-power-cc-tri-mode-led-driver-50w-1200ma/
Probably good enough:
https://www.trcelectronics.com/View/Mean-Well/LPC-60-1050.shtml
Search for "50W 1200ma constant current led driver". You want it to be IP66 or IP67 for unlimited outdoor use.
NY65912 08-19-2023 02:11 PM
Thanks Mike. I've been looking at that driver. I'm going to give it a try.
Cheers
