Debugging my battery charger
I noticed that my old Schuhmacher battery charger which connects to the cigarette lighter wasn't charging my P-car's battery. I connected a modern Deltran unit directly to the battery terminals and it fully charged the battery so I know it's not the battery that's the problem.
Naive question but when I plug the Schuhmacher into a 110V outlet I should be reading 12VDC across the tip of the cigarette lighter plug and the spring-loaded metal "clip" on the perimeter of the plug indicated with red arrows in the attached picture, correct? Right now I am getting 0V, which leads me to suspect that the plug has a problem. Thanks in advance.
-- alex -- I SWEAR: Forget Porsches - Lifted, fully kitted, gray Sprinter Vans seem to be THE NEW midlife crisis vehicles for rich people! Why??? Large wallet != very rugged |
Kantry Member
With that unit, does the tip piece have to be depressed to complete the circuit?
If not, you might have a broken contact within the plug. Best Les
Best Les My train of thought has been replaced by a bumper car. |
Platinum Member
I'm not sure about that one but the smart schumacher chargers will not read voltage with a volt meter without a battery connected.
Are the lights working on the charger? If you measure across the car lighter jack, does the car measure 12v?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 08-27-2023 at 01:11 PM.. |
Or the charger itself...not familiar with that brand of charger, but it should be producing more than 12V...if memory serves, mine puts out 13.4v. I have a set of multimeter leads that probe a pin into the wires themselves. Best way I can describe them is that they have a hook shape tip to hold the wire, with a needle like spring fed probe to penetrate the insulation. Look for test lead sets on Amazon.
Anyway, I'd suggest bypassing the plug, and testing the wires. If you still get zero...yep, time for a new battery maintainer.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Constitutional Liberal
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Thanks for the quick responses. See below:
Platinum Member
1995? I'd replace it with an automatic smart charger and not look back. Probably better for the battery also.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Super Moderator
Most of those cigarette lighter plugs have a fuse inside. I'd check that first.
^Good thought! Also, is the fuse controlling the car's plug in still good? Remember once thinking a radar detector had died..turns out I'd somehow shorted the cigarette lighter outlet and had blown it's fuse.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 08-27-2023 at 03:15 PM.. |
