-   -   Help (http://forums.pelicanparts.com/off-topic-discussions/1145712-help.html)
yellowperil 09-02-2023 04:14 PM
Help
The ignition key in my Cayman often comes apart, the key blade from the key fob, which I don't like. It's awkward to get it back together.
Is there a easy fix for this, is it possible to glue it together? I'm stumped.
Help please !
LEAKYSEALS951 09-02-2023 04:19 PM
This help?
http://forums.pelicanparts.com/uploa...1693696730.JPG
Steve Carlton 09-02-2023 04:23 PM
Nail bite much, Leaky?
Zeke 09-02-2023 04:29 PM
Snarky. I'm sure you're perfect.
yellowperil 09-02-2023 04:32 PM
Perhaps I should have said the blade comes OUT of the fob and then its a fumble to get it back in place,
sc_rufctr 09-02-2023 04:42 PM
Why not buy a new fob case and swap the board & blade over? (assuming your current one is worn out causing the issue)
LEAKYSEALS951 09-02-2023 04:43 PM
That's the only way I can get the grease out under my fingernails!!!!
(I'm also stressed my key fix won't hold?) btw- does the volvo extended warranty cover remote keys battery covers? (or lee press on nails?) :)
sc_rufctr 09-02-2023 04:49 PM
Leaky... Looking at that photo of your thumb, it's obvious to me your nail was cut short not bitten.
All the best!
john70t 09-02-2023 07:44 PM
(Remove the 5lbs of other keys and flashlights attached to it also. Good for the column switch.)
Er, sorry to be snarky heh heh.
Sounds like a new case might do it without any further info or pics. Should be a board with switches under the case buttons, a key pivot and release, and a spring inside. A little WD40 and very thin filler material (Al foil strip?) might seat the plastic clam shell screws a bit better if they are stripped and getting loose. Go easy with that plastic. With locks I try to tighten/lube/work it back and forth slowly to find the problem. The new ones are pricey but it's good to have an extra just because.
JackDidley 09-02-2023 08:53 PM
The obvious answer, get a new Cayman.
