Good move, Charlie!
Here's a kit to add a filter downstream of the HPFP:
https://whitbreadperformance.com/products/3-0l-tdi-cp4-metering-valve-bypass-kit?variant=44741025857695 |
I’m not sure of seafoam (isopropyl alcohol) in a common rail diesel. Let alone one that has emissions equipment. |
That is what damages expensive pumps, lack of lubrication that used to be in diesel fuel. Still, these modern systems should be designed to operate well on modern fuel blends but reality is that they do not always, as you have already experienced. |
Any of the major brand additives will work also. ( Howe's, Power Service....) Some guys use a mix of 2-stroke and Marvel Mystery oil added to their fuel. Was an issue with the 2nd gen Cummins, where the lift pumps were cooking because of the crappy ULSD's lack of lubricity, which in turn would shred the Bosch injector pump. . |
I think they replaced the entire fuel system; tank injectors pump filter and all lines. |
| All times are GMT -8. The time now is 10:40 PM. |
