Duramax repair estimate- in the ballpark ?
Hey guys my 2001 Duramax diesel is starting to have a slight lumpy idle . She has 190,000 miles and runs fine otherwise . I stopped by a local independent Duramax shop today and they checked injector balances .
Two of the four injectors on the passenger side are out of spec . One is way out . He also said fuel pressure regulator is right on the ragged edge so needs replacement . So we had a discussion on what makes sense to do . The shop owner recommended to replace the CP3 pump/pressure regulator along with four injectors on the passenger side . The injectors on the drivers side were well within spec . I have purchased an aftermarket lift pump with an additional fuel filter that he said he would install for me . Estimate was $3500.00 total . He said they would have the truck for 3 days . All parts will be OEM Bosch . I personally think the quote is reasonable but wanted to hear what you guys think . I can't afford to replace the truck and I am fond of the old gal . |
You do not have permissi
For all I know (for the round file):
1). Check battery at rest first. After applied oad like defrosters and fan, with key off (KOEO) to establish a chemical low point under load. Should maintain 12.2V minimum if it's been run recently. Recheck while at mid idle. Alternator should supply 14V+. No electronics work without electricity... 2). Buy a six pack of fuel filters and use them proven cleaner additives. Change filters each week even after everything is back to normal. Drive 'er a bit harder and open up them injection valves full. No injector motor solenoids works when gummed up with twenty years of sludge... 3). Use a throttle-body safe spray that's ok for electronics. 4). When those are both good, finally look into injector cleaning and/or fuel pump replacement. Everything else is clean and has been ruled out. (grain of salt: I don't know diesels)
Meanwhile other things are still happening. |
Still Doin Time
I know diesels fairly well, but not Duramax specifically. The current technology of common rail HUEI / injectors is really good, until they aren't. If the OP went almost 200k without opening up the engine, especially Duramax that's a pretty good run. As far as pricing, you may want to check around but sounds reasonable as most shops are @$125 / hr and up for labor, then add good OEM parts, not too much of a stretch to get to that number.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
I have a 2009 Duramax in a 2007 Suburban.
Engine has Airdog lift pump and filter, no EGR, deleted factory fuel pump, after market air intake, chipped. Every time I change the transmission fluid I dump about half of the old fluid in the fuel tank, (about half a tank of fuel when I add the tran fluid). My mechanic swears it is the best way to keep injectors clean.
Chris 89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute |
Still Doin Time
^^ you're close. Auto transmission fluid is very high in detergents, and yes adding that to your fuel system helps cleaning the injectors of stiction. But old fluid has lost / used up that detergent not to mention clutch friction particles that should be discarded. So good practice but use new fluid, and when the manufacturer allows fuel filter fill w/ diesel to cut down on aeration on start, fill it with clean ATF instead.
Good tip on adding clean new transmission fluid to the fuel tank . I am going g to try a few tanks of that to see if any changes . If not I will bite the bullet and have the repairs done .
I have a lift pump from Kennedy Engineering along with their install harness and filter bracket . I purchased a NAPA fuel filter mount along with a water separator filter . So plan is to get that installed and run two filters . I purchased the truck years ago with 100k miles on it . I have had a mechanic say he sees signs of the injectors being replaced . So if he's correct these injectors have 90k + on them . |
Edministrator
Good post? Leave a tip! O - $1 O - $2 O - $3 |
I drive on the roads that was filmed on literally every day. The location where the truck tries pushing the car into the train is a mile from my house.
Michael |
Edministrator
I wonder if anyone would get the joke if you drove a red Plymouth Valiant around there regularly.
I put a quart of new transmission fluid into the fuel tank . It holds 32 gallons and is about 3/4 full . Will burn that tank and do it again . Hopefully good things will happen 😁
If the truck is in good condition otherwise...esp the body, I would say that price is worth it if you don't get it fixed on your own.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Navin Johnson
This stuff is popular in the Ford Powerstroke community.. The 6.0 was condemned as a POS engine... apparently I'm one of the lucky ones, with the exception of routine maintenance mine is reliable
Anyway... Hot Shots Secret I guess forgive the sensationalized "bro" name... I had some conversations with Lubemaster about this product, and he held the product and Mfg. in high regard.. I use it because they often offer it as a package with some of there other products at a heavy discount. Obviously it won't cure injectors that are mechanically failing....
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 10-06-2023 at 04:07 PM.. |
The body is in good shape the bed is damaged . But I have a steel flatbed to install . The truck overall is in good shape . So it's worth putting $$ into it but I will try some home remedies first .
TimT thanks for the suggestion . The mechanic said the two injectors that are out of spec are returning too much fuel back to the tank . I don't know if that means a hard failure vs gummed up . So for now I will go down the path of gummed up .
I use Hot Shot, recommended by my wrench, once a year and try to use bio-diesel to keep everything clean. I read Bio diesel keeps injectors very clean. My injectors are perfect but then, it was replaced 40,000 miles ago.
