Nothing to add that has not been already said, but my son had an Audi A4 that would do exactly what you are describing. I checked it and found nothing. I took it to the best indy I know and he found nothing. Took it to Audi they had it for 2 weeks and charged me $500 and they found nothing. Finally just got rid of it and got him a new car. That solved the issue right away.
Any update?
So what was the problem?
Funny y’all are asking…
So we put in a new alternator. I hand the car off to the daughter. We are leaving for a trip to New Zealand shortly and leave my wife’s car and a key with the daughter “just to be safe.” Car seems great for about a week. I am checking in with daughter daily. Until it wasn’t. Threw a code something about glow plugs. Went into limp mode. Called the mechanic today (we are now back from vacation) and am negotiating with daughter to pick up the car. I am not going to clear codes so the mechanic can see the whole story. I was planning on an update but now you get to see the progress real time. I do think this is progress. We have a hard failure somewhere. Prior we only had intermittent issues. Mechanic seems to be pretty sharp and not super expensive. So yay for that. More to follow… |
I'm pretty late to this thread but this is worth a read. I thought 'battery registration' was bunk until I replaced the battery in my X5 and still seemed to have charging and battery warning problems. Worth a quick look anyway.
https://www.midtronics.com/blog/battery-registration-what-why-and-how-to-do-it/ SmileWavy |
Wow! Never knew about “registering a battery”…but I believe it! Been retired for 12 years but still remember the customer’s Cayenne whose mirrors and windows worked backwards of the way the switch was operated. After 3 days of trying to figure it out (switches, window motor logic recode, etc, etc) I finally called the PCNA help desk and they said “oh, code it for having lighted door sills even tho it doesn’t”! Problem solved. “Today’s car's electrical systems are complicated” is a major understatement!
^^^Gogar for yet another piece of the puzzle. I did some Google on this. Not sure if it is needed or not for a 2014. I will call the dealer today. Filing this under “things I never knew or even anticipated.” Thanks!!!
I don't think battery registration is req on this car, I did not see any battery monitor device like BMW uses anyways. That system was developed to solve a problem that was not there, was supposed to help battery life by charging at a slightly lower voltage and go higher as the battery gets older, something like that. Also be able to adjust charging voltages and current for lead acid vs AGM batteries.
| All times are GMT -8. The time now is 07:57 PM. |
