Evil Genius
Rusty Heap's Avatar
Foam Cannons are great for washing cars.
Putting the cars away for the winter and their final wash before the car cover goes on. On my Off-Road rigs I use a foam cannon on my pressure washer to get rid of all the grime. It coats my C4S well, in a ton of foam.
I highly suggest you pick one up. Cheap on amazon right now.
https://www.amazon.com/Tool-Daily-Cannon-Connector-Pressure/dp/B07HC898GM/ref=asc_df_B07HC898GM&mcid=49a9234cb60a3c449fd7c398042559ef?tag=bingshop pinga-20&linkCode=df0&hvadid=79989526348979&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583589103197204&psc=1
Life is a big ocean to swim in.
Wag more, bark less.
Old 11-23-2023, 10:20 AM
Counterclockwise?
Do you need special soap and how much did you use?
Rod
1986 Carrera
2001 996TT
Old 11-23-2023, 10:40 AM
Evil Genius
Rusty Heap's Avatar
Standard Car wash soap, I used Macgyvers Gold. maybe 1/2 cup of liquid. Doesn't take much.
I gotta try this! my whole house siding.
Old 11-23-2023, 10:45 AM
Almost Banned Once
sc_rufctr's Avatar
I've been doing the same for about 12 months. The trick is the dwell time. Let the foam do its job but no too long. When the car is really dirty I still use a sponge. Note the extra long pressure hose for my Karcher. Mine is 7 meters (7.65 Yards) long. That alone make life really easy.
About 5 minutes later and just before the final rinse.
- Peter
Old 11-23-2023, 10:48 AM
Not mine but a friend with a severe case of OCD put this together.
http://cloud.tapatalk.com/s/655fa836f0692/Simple%20Car%20washing.pdf
Old 11-23-2023, 11:30 AM
Zeke's Avatar
Been looking into FC's. It all looks good. Just wanted to say I've spent some time on the subject.
Old 11-23-2023, 11:36 AM
Model Citizen
herr_oberst's Avatar
What's the minimum psi pressure washer you could get away with?
I've been interested for a while but I don't have an electric PW, and I don't want to have to run the gas powered unit just to use a foam cannon; the electric one would most likely be dedicated to the cannon
Old 11-23-2023, 11:45 AM
Dr J's Avatar
It is great for pre cleaning but let nobody fool you into thinking you don’t have to hand wash it afterwards. Even if using a pressure washer, my experience is that it is never as clean as if you hand wash.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Evil Genius
Rusty Heap's Avatar
I foam, Wipe with a fiber mitt glove, then rinse.
Pre Spray rims with Simple Green cuts brake dust great.
Old 11-23-2023, 11:49 AM
Navin Johnson
TimT's Avatar
You don't need a pressure washer to use a foam cannon..
I picked up a chemical Guys detailing kit when I bought my Cayman, and a hose end foam cannon was included
Foam Cannon
'69 911 GT-5
'75 914 GT-3
and others
Old 11-23-2023, 11:53 AM
After battling the water and hose and trying to find a shady spot to wash the car, I switched to Maguire's Waterless Wash and Wax.
I like it a lot...it's been at least 3 years since I've used water for the cars.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 11-23-2023, 01:32 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
Maguires Hybrid Ceramic Wax - I hate it. Tried two full bottles. (Blue stuff)
Maguires Hybrid Ceramic Detailer- I LOVE this stuff. (Green stuff). I use this after every other wash. Been using it 2 years. Try it.
I need a foam cannon.
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 11-23-2023, 02:37 PM
Zeke's Avatar
No, you don't need a pressure washer but it does help. Just use the large fan and get close when you get to the wheels.
Old 11-23-2023, 02:55 PM
ted ted is online now
likes to left foot brake.
ted's Avatar
FC sounds about as good and quick as a commercial car wash.
FC doesn't remove oxidation right?
Before I wax a car I like to remove all oxidation with a clay bar micro fiber towel.
Old 11-23-2023, 03:26 PM
Evil Genius
Rusty Heap's Avatar
This is the Soap/Wax I use.
https://www.amazon.com/Meguiars-G7164-Class-Shampoo-Conditioner/dp/B0009IQXFO?ref_=ast_sto_dp&th=1
Old 11-23-2023, 04:48 PM
I ahve been thinking about getting a pressure washer. No more gas, it will be elect or even battery only I never need anything that powerful anymore. With this foam, do most of you just shoot, let sit for a certain amount time so the foam does its job, rinse off, dry? I have been dying to try Turtle Wax's wet wax. Pour it on when the car is still wet. Dry and its shiny again?
Old 11-23-2023, 11:45 PM
Almost Banned Once
sc_rufctr's Avatar
Mine is a "Karcher K 2. 180." bought more than 10 years ago. It works really well (& it was cheap) but I don't know what PSI it's rated at.
However the current "Karcher K 2" Pressure Washer is rated at "Maximum 1750 PSI".
- Peter
Old 11-23-2023, 11:48 PM
Almost Banned Once
sc_rufctr's Avatar
You are correct Mr Ted. Nothing works as well as a proper hand wash but I can FC my car in about 15 minutes total (drip dry except for the flat surfaces and the windows). The trick is to do it often but I use about 100 mils of soap with ever wash so that's something to consider.
- Peter
Old 11-23-2023, 11:53 PM
Pete, tell me about this clay bar micro fiber towel. Do you use it black side down, drag it across a roof or hood over water or detail solution or it is just another name of a series of micro fiber towels?
Old 11-23-2023, 11:58 PM
