-   -   Why did my Piston and Rings Blow Up? (http://forums.pelicanparts.com/off-topic-discussions/1151773-why-did-my-piston-rings-blow-up.html)
Rusty Heap 12-07-2023 12:05 PM
I've got Blown Piston dome and Rings on my 2021 KRX Side x Side with 1500 miles. It started smoking on the trail. I did a compression test. Left was ~150 psi, Right was only 60. It was time for the dealer and warranty coverage. They tore the top end down to find right piston missing most of the rings and piston dome/skirt that retains the rings.
Detonation? Doesn't look like I'm running lean........always use Premium 92 octane so it's not pinging.
Brain Trust thoughts?
http://forums.pelicanparts.com/uploa...1701979335.JPG
http://forums.pelicanparts.com/uploa...1701979335.jpg
908/930 12-07-2023 01:09 PM
Not sure but I think you floated your exhaust valves and they made contact. Any marks on them?
cstreit 12-07-2023 02:45 PM
...boy that sure LOOKS like detonation. Bad gas?
Jeff Higgins 12-07-2023 02:49 PM
Classic high rpm detonation. I wish you had seen these before you stopped by yesterday, I could have shown you some Porsche pistons that look like that.
When you get it back, we should put my LM1 on it and get some A/F readings. What with modern emissions requirements, even on "off road" equipment, I bet it's running lean as hell. Is there any way to alter the fuel injection to provide more fuel?
sc_rufctr 12-07-2023 03:33 PM
It could have been an incidental failure... As in "One in then thousand".
Sometimes thing break for no apparent reason.
Tobra 12-07-2023 03:49 PM
yeah
911boost 12-07-2023 04:25 PM
It’s not a Polaris!
Haha just kidding that sucks. I agree detonation.
LWJ 12-07-2023 07:07 PM
Yikes!
I agree that it is almost certainly tuned very lean.
Dirty filter, bad gas, something else, can make it go even more lean very quickly.
And, then this is the result.
Jeff Alton 12-07-2023 08:47 PM
Detonation..........
pavulon 12-08-2023 02:28 AM
There seem to be forums for almost everything ever made. Any mention of this or similar in those?
wdfifteen 12-08-2023 02:43 AM
Ring land collapse like that is almost always premature ignition. As many here have said, a lean mixture can cause it. So can timing going too far advanced at working rpm. Given how black and moist the combustion chamber looks my money would be on timing.
1990C4S 12-08-2023 06:31 AM
It can also be insufficient ring gap, no? Rings expand, lock up, and the land fails?
red 928 12-08-2023 02:26 PM
That's what I was thinking.
wdfifteen 12-09-2023 07:11 AM
I suppose so. There would probably be a lot of cylinder wall scoring and I would expect the ring land would have failed pulling up instead of collapsing down.
Bob Kontak 12-09-2023 10:08 AM
Injector flow may have been compromised if everything is stock as to factory settings.
gduke2010 12-09-2023 10:12 AM
Extreme heat or an injector stuck open.
wdfifteen 12-09-2023 12:06 PM
How is the top ring fitting in the other piston?
Por_sha911 12-09-2023 06:44 PM
...boy that sure looks like detonation. Bad gas?
+1
Bob Kontak 12-10-2023 05:44 AM
A neighborood car acquaintance showed me the pistons out of his 930 that suffered detenotation. They were melted on that edge and down the side a half inch.
Different variables.
Dan J 12-10-2023 04:39 PM
Bad injector
