Lightbulb How To Remove Rust With Electrolysis In Six Easy Steps
I've been using vinegar for rust and corrosion removal on small hand tools and also some of my motorcycle fuel tanks.
It seems to work well but am wondering if electrolysis would be a better method.
I ran across this YT vid which shows how it's done.
In the comments section, it's mentioned that using Sodium Carbonate works better, and to sand off where the wires attach for a better connection, and to use coated wire where it enters the solution. I also read in another vid to use several different connection points on the rusted item to help the process.
Thoughts?
Old 12-31-2023, 09:58 AM
Flatbutt1's Avatar
I'm thinking Shaun is the SME on this.
big blue tricycle
stare down the darkness and watch it fade
Old 12-31-2023, 10:30 AM
weekend wOrrier
I did electrolysis on my garden tractor fuel tank. I will try to hunt up some pics. Very messy. Very satisfying to do. Takes forever. You think you are done with a tank, but, no, you are not done! Rinse. Repeat. Rinse. Repeat. Rinse. Repeat. (A week later....) Rinse. Repeat. I was surprised there was any tank left when I was done.
100% narcissist
Old 12-31-2023, 10:50 AM
Zeke's Avatar
Washing soda is what I've heard. All it does is make water a better electrical conductor. Once just for grins I threw a live 120v extension cord into a swimming pool. Nothing happened. I unplugged it and pulled it out, let it dry and it was fine.
Also, running a charger through a battery is a good process. You don't need a big battery either.
Honestly that vise would have turned out better in Evaporust.
Old 12-31-2023, 11:45 AM
Used it multiple times and it works very well. Sodium Carbonate is simply washing powder…I use Muel Team Borax available in grocery stores. Multiple anodes, like short lengths of rebar help speed up the process but any metal will work. You will need an old school battery charger as the smart ones will not work. It does produce hydrogen gas so don’t be foolish and put in a closet or you
“could” make a big boom and rearrange your abode.
1986 3.2 Carrera
Old 12-31-2023, 11:47 AM
One of the forum members in one of the VFR forums said he's done 5-6 fuel tanks using electrolysis and it worked very well. Said to remove the petcock and cap first.
I might just try it on one of mine and will keep everyone posted on my findings.....
Old 12-31-2023, 12:13 PM
Tanks are different….the anode goes inside the tank.
Gas Tank Cleaning using Electrolysis
1986 3.2 Carrera
Old 12-31-2023, 01:10 PM
I'm a member of a vintage tool group on Facebook. There are lots of folks that restore old tools. Vinegar and other caustic methods work, but can degrade the parts/metal. One of three guys had written up his methods of doing reverse electrolysis. I'll grab it and post it here shortly.
Old 12-31-2023, 01:26 PM
Senior Member
Superman's Avatar
Some folks on SOHC/4 use this technology on old rusty NLA tanks. IIRC it takes a few days to complete. But.....when complete that gas tank is CLEAN. Shiny clean. ALL of the rust is removed.
Mocha 1978 911SC. "Coco"
Old 12-31-2023, 01:38 PM
I'll admit that I ddin't watch much of the video. I have used this method (washing soda / sodium bicarbonate, a big bucket, steel electrodes, and an old high-capacity battery charger) and it worked well. A couple of tips:
- Brush/scrape as much rust off as you can.
- Thoroughly degrease / pressure wash and dry the parts.
- I've used both multiple pieces of rebar and steel wire mesh for electrodes. It was most effective when I lined a circular bucket with wire mesh and put the part in the center of the bucket so it was equidistant from all sides.
- Watch the amperage on the batter charger; surface area and electrolyte conductivity determines current draw.
Old 12-31-2023, 02:18 PM
I think Evaporust is still the best, but it's not cheap. Electrolysis is cheap, but not as good as Evaporust.
Submersion in vinegar, or diluted molasses work if you're patient.
My favorite is still phosphoric acid etching. Cheap, fast, and relatively easy.
Lastly, what a chump, leaving the vise assembled. Take it apart and do it right.
Old 01-01-2024, 10:48 AM
Zeke's Avatar
Evaporust is good for about 15 sessions depending on the amount of rust. Excellent for a special project that needs TLC like a small steel toy car. Not great money wise for dunking rusty tools and iron bits.
Old 01-01-2024, 11:02 AM
Arizona_928's Avatar
I use a 50 dollar power supply from amazon...
After treatment is important, so that it doesn't rust again...
It's also sodium bicarbonate... Na + HCO3-
dolor et pavor
Copyright
Old 01-01-2024, 12:53 PM
Evaporust is a chemical that removes rust through the chemistry process of chelation. When a rusty part soaks in a bucket of Evaporust, the molecules of Evaporust attach to rust molecules and remove them from the surface of the part. Eventually all the rust is picked clean from the surface. There are two big downsides to this process. First, Evaporust will leave the part with the ugliest uniform dull gray color you can imagine.
If any part of the tool sticks above the Evaporust solution while soaking, you’ll create an endless chemical reaction at the waterline where rust is continually created by oxidation and then removed by the Evaporust. That will produce a deep irreversible line in the metal of your tool at the waterline.
use Evaporust in two situations: (1) On iron parts when I want to remove rust with as little work possible (for example if I plan to turn the part black again by bluing or seasoning with oil then baking it) or if I just don’t care what the parts look like afterward and (2) on small parts such as screws and washers when I plan to buff them with polishing compound afterwards to restore their shine. Each part in a reverse electrolysis operation must be connected to the power source, and it usually isn’t convenient to do that with a bucket of screws.
Old 01-01-2024, 12:58 PM
Zeke's Avatar
If the part is plated the ER will not remove the plating. So the outcome is not always a ugly dull gray. It depends on the alloy. It it rusts, then ER will remove the rust. Some SS rusts but it comes back looking like SS. For sure it has to be ferrous. Ball bearings have a lot of chromium in their alloy. If they happen to rust they are useless, but the point is that chromium doesn't blacken much at all. Not talking about chrome plating.
On Practical Machinist someone put a piece of steel that had a fresh cut at the end in ER and while the rusted surface was blackened with carbon, the cut was somewhat bright. It was also pointed out that once the rust is gone what you are seeing is result of what rust does, i.e., pitting even if micro pitting. So the original finish is lost.
I did a lot of reading about ER months ago. Many have come close to reproducing the formula using anything from beet juice to molasses (a known rust remover). There is a lot more to it than combining a ratio of beets and molasses. But it's pretty well known that the compound is organic.
You can get decent results with a home brew, but so far not quite the same.
Old 01-01-2024, 02:23 PM
An important aspect of the discussion is how to keep your stuff from flash rusting immediately after treatment.
I've been spray coating mine with Fluid Film. It contains "lanolin" and also serves as a lubricant.
Here is a current vinegar soak of some small hand tools.......
Tomorrow I will remove, wire brush by hand, soak with a baking soda solution, rinse, dry off, then spray down with Fluid Film.
Here are some I did weeks ago.......
Old 01-01-2024, 03:09 PM
Model Citizen
herr_oberst's Avatar
I think Evaporust is magic. Best stuff ever for what it's designed for.
Just don't use it with magnesium.
Old 01-01-2024, 04:05 PM
A930Rocket's Avatar
I used Evaporust or something similar on a caliper and it broke the “spring” on top. Somehow it changes the composition of the metal.
Old 01-01-2024, 07:03 PM
Flatbutt1's Avatar
Proof that sometimes rust is the only thing holding stuff together.
Evaporust is essentially EDTA. If the rust runs deeply enough and the EDTA chelates it, then it's realistic to expect that metal piece to fail. IMO
big blue tricycle
Old 01-01-2024, 07:46 PM
pwd72s's Avatar
Project farm on both electrolysis and evaporust:
Old 01-01-2024, 10:33 PM
