-   -   Air hose with reel , is there a good one? (http://forums.pelicanparts.com/off-topic-discussions/1153063-air-hose-reel-there-good-one.html)
afterburn 549 01-03-2024 12:17 PM
Shop hose and reel all assembled.
Can anyone recommend a good unit with 75 feet of hose?
One that will wind up with 175 lb pressure in it?
No harbor freight crap, please.
I have tried a few, not happy with amazon selection or HF, and all the cheap crap.
For sure i dont need an end flying off and a hose end beating a car to death.
I am looking / hoping for an American-made unit.
Any input is appreciated.
Thanx!
herr_oberst 01-03-2024 12:36 PM
Thanx!
https://www.factorydirecthose.com/collections/air-hose-reels
wdfifteen 01-03-2024 01:09 PM
I have a DeWalt. I like it, but it only holds 50 feet of heavy 3/8 hose
Bob Kontak 01-03-2024 02:06 PM
I think the Coxreel stuff Herr-oberst posted is a big step up from Harbor Freight.
That said, I have had a harbor freight reel for close to twenty years and have spent a boat load of time in the garage only changing the hoses.
I bought a used Reelcraft (three years ago) thinking HF surely sucked the big one only to find the Reelcraft needed an unservicable fancy swivel fitting. $200 for that fitting. Mind you this was a large reel from a fire station. Not really our application.
The used Reelcraft went into the dumpster and the HF went back up on the wall.
HF says this Reelcraft is a good comparison to their $109 top of the line unit. Reel craft is more than HF says from quick checks. Similar to the Coxreel.
https://www.reelcraft.com/product/interactive-catalog/air-hose-reels/general-air-hose-reels/dp5650-olp-3-8-in-x-50-ft-compact-dual-pedestal-hose-reel/
2.7RS 01-03-2024 02:15 PM
Grainger.
Good stuff, plenty of choices
https://www.grainger.com/category/pipe-hose-tube-fittings/hose-hose-fittings-hose-reels/hose-reels/air-water-spring-return-hose-reels/air-or-water-spring-return-hose-reels?tv_optin=true&searchQuery=speedaire+hose+ree l&searchBar=true&suggestConfigId=6&tier=Not+Applic able
908/930 01-03-2024 02:32 PM
Do you actually run 175psi in your air line? I think most air tools are intended to be around 100psi max.
Alan A 01-03-2024 06:59 PM
I use a HF reel and a better (100’) line on it. It was good for 15 years and was way cheaper than anything else I found.
I had to replace the banjo fitting and the 3’ connecting piece last year, but I can live with that lifespan. The line is still fine. I mostly run air tools off it.
red 928 01-03-2024 11:39 PM
LOL you could get a 3/8" x 100' reel from snap-on for $400 ;)
personally I use a $50 (when I bought it)
3/8" x 50' reel from HF without any problems in 10 years.
I do not keep it pressured up all the time though,
I only turn on the compressor when I need it.
Robert Coats 01-04-2024 04:25 AM
I bought a Reelcraft wall-mount about three years ago, and it has been bulletproof. Spendy for sure, but buy once, cry once. I like the black 'donut' that you can park anywhere on the line and have exactly the length of slack you want. I mounted it high on the garage wall, and it stays up and out of the way. The only quirk is there is a bit of a trick to get the reel to lock in position, but after a bit of practice, I can lock it with no drama.
Bob Kontak 01-04-2024 06:06 AM
Interested in response. I have seen a guy run that normally. Man, bolts and nuts came off.
He will have a regulator at least.
1990C4S 01-04-2024 06:17 AM
Aside from filling tires with air, why do you even need an airline anymore?
herr_oberst 01-04-2024 06:30 AM
Like the vast majority here, my HF with 50' of hose has served me well for decades (and I also recently replaces the 3' jumper hose.)
I mostly use my compressor to fill tires and for the blow gun but I also have a full compliment of nail guns, and my rattle gun is fired by air. I could and should get rid of the big tank and just get a little pancake or hotdog compressor to free up some space in the shop.
Jeff Alton 01-04-2024 07:17 PM
In our shop, we have 10 hose reels mounted on hoists. All from Newline . A local company, but they do not manufacture them.
Had to replace one burst hose and one reel, over 14 years...... This is in a shop where every hose reel gets used every day....
We run our shop pressure at 135lbs. Anything above that messes with your tools....
Cheers
Dan J 01-04-2024 07:33 PM
I think the 75' thing will be a problem. I have Milton 3/8 x 50 and they are very nice
Like Jeff used all day 5 days a week for years. Had cheap **** before not worth the aggravation
afterburn 549 01-05-2024 02:30 AM
Prolly not quite? , the compressor kicks off at 175lbs. Air runs through a 50-foot reel.
I do have a separate outlet and hose for the 3/4 gun which runs 1/2 hose straight through, no reel.
The compressor is two-stage - Porter Cable. Big cylinder and a smaller cylinder
The tools have not ever complained about it, in fact, I have not even ever thought about it .
I use them quite regularly and owned this compressor for 17 years .
Same tools for over 30 years.
I do usually dribble a bit of oil dwn them B4 I pick them up every couple days .
I use the two 1/2 guns a lot, the 3/4 drive a bit, and the one inch.....hardly ever anymore.
afterburn 549 01-05-2024 02:43 AM
Really?
My fleet does not go to the shop.
The tire changer and car lift are air operated.
I change out tires, and balance them.
Do All brakes, ball joints and oil leaks.
All valve jobs (which are getting fewer anymore)
Have a separate air hose, and regulator / dryer system for paint guns.
I hire out the AC stuff. (air conditioning).
http://forums.pelicanparts.com/uploa...1704451114.jpg
http://forums.pelicanparts.com/uploa...1704451279.jpg
http://forums.pelicanparts.com/uploa...1704451322.jpg
http://forums.pelicanparts.com/uploa...1704451422.jpg
afterburn 549 01-05-2024 03:18 AM
Projects abound here.!
From the last couple of days...just kidding, last couple of years.
We should have a picture thread as to what we all have been doing!
http://forums.pelicanparts.com/uploa...1704452624.jpg
http://forums.pelicanparts.com/uploa...1704452728.jpg
http://forums.pelicanparts.com/uploa...1704452807.jpg
http://forums.pelicanparts.com/uploa...1704452925.jpg
http://forums.pelicanparts.com/uploa...1704453073.jpg
http://forums.pelicanparts.com/uploa...1704453176.jpg
http://forums.pelicanparts.com/uploa...1704453293.jpg
I was making this cradle as we unloaded it!
http://forums.pelicanparts.com/uploa...1704453364.jpg
Bob Kontak 01-05-2024 03:35 AM
OK, air hose allowed.
afterburn 549 01-05-2024 03:43 AM
Argh argh argh
And , fill my tires?
LOL
The older I get, the busier I get , cause the slower I go, and, can't get nothing done.....
Bob Kontak 01-05-2024 04:29 AM
At 67 I need a fire under my butt to get an honest three hours work in. That takes eight.
