-   -   VW beetle question. (http://forums.pelicanparts.com/off-topic-discussions/1155762-vw-beetle-question.html)
Bill Douglas 02-03-2024 07:19 PM
VW beetle question.
It's actually a 1975 Kombi and asking on behalf of the guy next door.
He said it's getting a bit hard to drive as the rev's drop too fast and the engine stalls when he is shifting down gears.
To me it sounds like a deceleration valve issue. But I wouldn't know as it's been half a lifetime since I had a VW.
What are your thoughts and thanks.
Jeff Higgins 02-03-2024 07:26 PM
Tell him to release the parking brake. ;)
Bill Douglas 02-03-2024 07:33 PM
LOL, that could be it!
Evans, Marv 02-03-2024 08:23 PM
Accelerator pumps in the carbs gone bad ??? I know when they get bad enough, you have to keep giving them gas by pumping the accelerator when rpm's fall.
Bill Douglas 02-03-2024 10:52 PM
Oh, OK. I don't know about that stuff, but I'll pass the message on. Thanks.
id10t 02-04-2024 05:50 AM
Buy him a copy of Muirs book?
Chocaholic 02-04-2024 05:53 AM
Along the lines of Jeff’s suggestion, make sure there’s air in the tires.
I believe WDfifteen recently restored an old VW. Maybe ping him.
Superman 02-04-2024 06:16 AM
I'd say Decel Valve but I'm not sure this car has one. Unless it has an automatic transmission, then maybe. You know....one of those auto-clutch thingies.
Rusty Heap 02-04-2024 07:34 AM
The Bible is still available, but look at those prices!
https://www.google.com/search?q=muirs+vw+book&sca_esv=169ec34203698107&rl z=1C1CHBF_enUS943US943&sxsrf=ACQVn0-SoFm3_vYBSnuM-q0Q0BwMo3o3oA%3A1707060819205&ei=U66_ZfmPDPWH0PEPv YSOuAQ&ved=0ahUKEwi5hfSNgZKEAxX1AzQIHT2CA0cQ4dUDCB A&uact=5&oq=muirs+vw+book&gs_lp=Egxnd3Mtd2l6LXNlcn AiDW11aXJzIHZ3IGJvb2tIiBVQ5AlYug1wAXgAkAEAmAFuoAHS AaoBAzAuMrgBA8gBAPgBAeIDBBgBIEGIBgE&sclient=gws-wiz-serp
fintstone 02-04-2024 08:31 AM
probably really simple like a fuel filter or air filter...but maybe points or fouled plugs. A tune up would most likely fix it.
Bill Douglas 02-04-2024 10:35 AM
The engine is fine. It's one of those 1600 ones. The only problem with it is the rev's dropping to too fast when he throttles off. I don't know if he has the book. Other than this he seems to be quite good at working on it.
Zeke 02-10-2024 03:41 PM
Low compression engines don't fall off quickly when the throttle is closed. I'd be interested in hearing it as he turned it off at idle. He should turn it over by hand. If not relatively free to turn, it's binding and maybe ready to seize.
wdfifteen 02-10-2024 06:24 PM
I don't know much about post 1967 cars. They got too modern for me.
Don't waste money on Miur's book. Yes, it's a cult classic, but if you want to fix your own VW get the Bentley manual.
Evans, Marv 02-10-2024 08:02 PM
Another carburetion possibility could be a hole in thr float in the carb which will let the float fill with gas and not function right. That can make the rpm's drop when off throttle. If it dies without pumping the accelerator, that can be an indication.
HobieMarty 02-10-2024 09:51 PM
Maybe he needs this. https://uploads.tapatalk-cdn.com/202...aa674ad0b5.jpg
john walker's workshop 02-10-2024 11:25 PM
A '75 bus would be fuel injection, in the US at least.
Tobra 02-11-2024 06:05 AM
Check the vacuum lines
Bill Douglas 02-11-2024 10:30 AM
Thanks guys. I'll bundle up the suggestions and pass them on. Other than this deceleration problem it seems to go well.
