Author of "101 Projects"
New "The Valve Guides" video posted...
Hi all. Newest installment in our YouTube channel:
Let me know your thoughts! -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I liked it...that coil on plug tester is unique. Might have to check one out.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Is there background music playing?
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Here's another one posted today:
Another one posted today: -Wayne
Good...but I like the terrific tools more because it's for jobs I might do and can afford.
Your cars in the background are amazing.
You do not have permissi
Entertainment-wise, the first video was a bit boring and the individual segments too long for each one. It was just two guys rambling on about something specific and not used much anymore, not the Wayne who built an empire and rebuilds exotic sports car engines for fun. I do like the buddy thing in general and discussing all kinds of vehicles. The social element uh drives the aftermarket. Just virtually being around the equipment is an experience and inspiration in itself.
I'd personally love to see a super technical segment on tracking down a misfire on the 962 but it might not be what you want to get into solo. Different perspectives are good to have. "This happens during this situation and this is what I suspect. Could be carbs or plugs. I'm going to use a carb flow meter on the top of each stack to check check vacuum draw. Another way to quick check is with another X type of tool. There is an idle bypass screw here and a needle valve here. Is the butterfly tight etc. For the plugs I can use an In-Line Spark Checker which flashes with each spark but it doesn't show timing or failure under load which could also be the coil in which case I'd do X. Another tool is Y. Or use Z. I'll use a data logger and these are the types available. They don't cover proprietary software for stereos or convertible rooftops. Handheld or laptop/phone software which just needs a wire to the 16-pin OBD port. Having a logged history helps to see how things are balancing. TPS increases, MAP vacuum goes down while fuel curve rises temporarily while O2 sensor changes rich." (OBD is not relevant to 962s but you get the drift. It's the FPV of being next to an experienced mechanic and seeing what is being done, even if you are miles ahead of the viewer. FWIW https://www.youtube.com/@TechIngredients has a channel where he delves into everything from making stills to lasers to musical instruments.)
Meanwhile other things are still happening. |
Indeed, we might do a segment on "Porsche race cars from the inside out", but probably not an in-depth analysis of diagnosing a 962. That would probably appeal to the hard-core engineers, but likely not too many other people? Trying to keep it relatively simple, but occasionally we can deep dive! Thanks for the suggestion,
Wayne
-Wayne
Another YT channel that perked my curiosity was WhistlinDiesel https://www.youtube.com/channel/UCdqp0KK_Io7TwK5cJMBvB0Q.
He first comes across as a young spoiled redneck kid, with way too much money, and not enough brains, but there is something more to it. The format has a combo of traveling and exploring the outdoors all over the world, friends working together and big projects, a few heaping tablespoons of recklessness, and a bit of practical "oh **** we need to get this done now." -That channel is similar to the Jackass series combo from the 90's appealing to wild kids (the international Cannonball Run in particular) -Or the Top Gear standard mix format of luxury car reviews, doing dumb things with them, jokes, celebrities, travel, etc. I suspect, but may be wrong, that you don't want to parallel those and do something different. Of all the entertainment angles there seems to be themes: 1). A puzzle for the viewer to figure out. The tv drama series or mystery dropping hints on what is going to happen next. Random plot twists to reset the path. It's usually off balance. Keep watching for every every nuance and hint. A+ there if you figured it out. Makes them feel smart at the end. 2). A puzzle being solved before your eyes. The tech show with step-by-step on how to do it. Product reviews. Rambo defeating the entire Soviet Army alone. Worst case it can delve into late night infomercial territory drone. Sometimes real-life informative and it's a dependable train which you know will reach a destination. Good things are known and guaranteed at the end. 3). A puzzle already solved. It has already been created and we are all here to explore and enjoy it. Documentaries. History channel. The viewer is in the midst of the chat across the table or fixing a problem with friends. Expand and explore what is existing. Casual and relaxing. Or any combo of the above. IDK. Random thoughts here.
