-   -   Removing muffler clamps (http://forums.pelicanparts.com/off-topic-discussions/1158407-removing-muffler-clamps.html)
Zeke 03-06-2024 09:26 AM
Originally Posted by JackDidley (Post 12207326)
Hit them with an impact. If they come loose, cool, if they snap off thats easier than cutting them.
Agree.
Originally Posted by Steve F (Post 12207544)
A cut off wheel in a Dremel tool.
Dremels are useful but slow. I'd wear out or break 4 discs doing that job.
OP, you asked what to buy as a replacement. Well, anything I have bought including copper alloy nuts for exhaust and even a stainless stud and a brass nut, eventually get more or less seized. When you use enough heat to loosen nuts, they are no good anymore. New every time unless it's been only a short while since installed. Brass nuts are a favorite with many mechanics.
I've heard of using anti-seize and other lubes to install. I would use only a little. It will all turn to a galvanic reaction eventually. Exhaust gases will see to this. But there is some science to back up various anti-seize compounds all the way to nickel and silver.
911 Rod 03-06-2024 10:05 AM
Originally Posted by Shaun @ Tru6 (Post 12207581)
MAPP ia hotter than propane and will get the nuts to glow without the oxygen bottle and special torch. What I like about my oxy-mapp is the torch head is pencil with a tiny ultrahot flame. Bernzomatic standard bottle torch head and flame is massive in comparison.
Are you referring to a MAPP bottle that I can buy at HD?
rfuerst911sc 03-06-2024 12:12 PM
Yes Mapp is easily available at most box stores and hardware stores . Things may have changed but in the past you could NOT use a Mapp cylinder with a propane head . Please make sure all parts are compatible .
wdfifteen 03-06-2024 12:30 PM
Originally Posted by DWBOX2000 (Post 12207293)
I think the worse case the bolts snap and I just push through and remove..
That’s the BEST case scenario. You’re going to need to replace then with new stainless steel bolts anyway. The sooner you snap them and get them out of the way the better.
There is a tool called a nut cracker that will split the nuts in two if there is space to get it in there.
masraum 03-06-2024 01:52 PM
Originally Posted by Baz (Post 12207283)
Heat up the nuts first , so the metal expands.....
https://brobible.com/wp-content/uplo...t-she-said.jpg
Originally Posted by KC911 (Post 12207428)
LOL .... PP Blaster IS liquid wench!
LOL. He said "peepee". Otherwise I FIFY.
Without grinding, I think the worse case the bolts snap and I just push through and remove.
Right side clamps are all new fortunately.
That sounds like the best case scenario for a situation like that to me.
Bob Kontak 03-06-2024 04:56 PM
These are heaven on earth compared to the Necco wafer cut off wheels. Quick change arbor included.
https://www.amazon.com/Dremel-EZ456B-2-Inch-Rotary-Cut-Off/dp/B000FBLRVU/ref=asc_df_B000FBLRVU/?tag=hyprod-20&linkCode=df0&hvadid=309807921328&hvpos=undefine d&hvnetw=g&hvrand=7482522645597486068&hvpone=undef ined&hvptwo=undefined&hvqmt=undefined&hvdev=c&hvdv cmdl=undefined&hvlocint=undefined&hvlocphy=1023726 &hvtargid=pla-442575120396&mcid=c9ee983104db398396508fbbab5916ca &th=1
Bob Kontak 03-06-2024 05:01 PM
Yes. Propane torch head fits MAPP since the 90's at least. Don't know about the way back. Propane would work if you have the time.
Just cut them off.
Baz 03-06-2024 05:12 PM
Bought this a while back from Amazon....around $15 delivered w/Prime. Looks like they're 'unavailable' now.....
Jet Pencil Torch Kitchen 1300 Celsius Blow Torch Refillable Lighters Butane Gas Welding Soldering BBQ Lighter,Golden
Works great to apply pinpoint heat.......
http://forums.pelicanparts.com/uploa...1709773934.jpg
DWBOX2000 03-06-2024 06:59 PM
The rust god’s were with me. I soaked a few weeks back and did again last night. I used a tap and cleaned the bolts, lubed up with wd40 and pulled. Got all the nuts off and was able to spin clamps freely. Couldn’t get the bolt off the clamp with one bolt but could the other two off the expensive clamp. I will replace those bolts, Anyhow, I am dropping off Tuesday to have the mechanic put on the 986 soul valve pipes. He said likely 4 hours but really depends on those bolts and the hassle. Should be piece of cake now. He can replace clamps if needed.
Thanks all. I really appreciate the help.
Bob Kontak 03-07-2024 07:43 AM
Good job!
Baz 03-07-2024 08:10 AM
Good job!
So what kind of wrench did you end up using?
DWBOX2000 03-07-2024 08:12 AM
Thanks.
Not the impact. It’s one of those wrench’s with a bend on the end so not flat. Not sure what called.
Baz 03-07-2024 09:15 AM
Originally Posted by DWBOX2000 (Post 12208255)
Thanks.
Box end?
https://global-fs.webike-cdn.net/cat...-010_02_TL.jpg
