Let’s discuss Hot tub chemicals…chlorine alternatives
What do you use other than chlorine for your hot tub? Wanting to get away from chlorine but not looking for an involved system. What are you using that’s gentle on the skin and able to keep up with daily use?
1986 3.2 Carrera
Old 03-11-2024, 04:55 PM
rfuerst911sc's Avatar
I know zip about hot tubs , but my guess is salt or potassium chloride .
Old 03-12-2024, 03:27 AM
I use Bromine tablets. No fancy floating dispenser, I put about 5 in a small draw string nylon bag and toss it in. Not nearly as harsh as chlorine and the water is clear
Old 03-12-2024, 04:30 AM
greglepore's Avatar
I used one of those mineral cartridges-a "frog" or whatever they're called, to cut back on bromine use.
The best thing I've had, though, was an Ecosmarte - https://www.ecosmarte.com/pool-spa - used on a swimspa. Not cheap, the spa system is 1600, but no odor or chemicals at all. It uses ti and copper plates and an electric current to generate sanitizing copper ions. You do have to keep acidity in line for it to work, but easy and worth it. Only negative is that it can turn bleached blond hair green, reversible with lemon juice.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 03-12-2024, 05:10 AM
Zink Racer
My tub was bought in 2015 and has an ozone system and "clear ray" light system. I do use chlorine, but these technologies keep it to a very low level. No issues with odor or skin problems and if there were, my wife would be all over it :-)
Jerry
1964 356, 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, a couple of other 914's in various states of repair
Old 03-12-2024, 05:41 AM
Evil Genius
Rusty Heap's Avatar
https://spadepot.com/products/oxy-spa-non-chlorine-mps-shock-ca1021
Life is a big ocean to swim in.
Wag more, bark less.
Old 03-12-2024, 08:51 AM
