battery jump starter?
Durmax been sitting for a couple months. Click, click, click, siht. Dim head lights, so off to get my trusty Antigravity booster. Talk to the rep when I bought it and he swears up and down that it will turn the engine of a big diesel. Nope, been lie to again. It didn't move anything but a click. I even tried with my old Schumacher charger set up at 50 amp jump start. Nothing waited 10 min and it bearly turned the engine over once. Left it charging for 15 min at 10 amps and it started right up. Maybe there's not enough electron flowing through those stupid little side post GM like so much. I hate those side post batteries. The Interstate batteries in there are only 4 months old. Think any damage to batteries? What jump starters do you guys use to start a big engine like that. There are dual batteries under the hood of that truck.
How much peak amp is really needed for drain batteries on an engine like it? I see them up to 1800-2000 maps. Is it really necessary to get the biggest possible peak amp output or are they rated by cold cranking amps like a traditional starting battery?
I don't think anything less than 3000 amps is worth looking at . Higher would be better . I haven't had to jump my Duramax so I am just going on what manufacturers are saying in the ads . Most 2000 amp say " up to 6.0 L diesel " . And even if they are accurate in the description that's probably best case in laboratory conditions . Real world I want more oomph . Here is one example:
https://www.amazon.com/Portable-Car-Battery-Jump-Starter/dp/B0CRYTDKLW
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
It never did start a car that was dead. I think if the car is turning over slowly and not going to start, that's when you use it, not beyond. |
^^^ Well that stinks ! Sorry it didn't last the reviews look good .
Jeff, looks like you've seen this movie before:
https://forums.pelicanparts.com/off-topic-discussions/1080427-solar-trickle-charger.html |
FWIW, I've had to use a jump pack (bought from NAPA).and another truck to light off my 2006 6.0L Ford.
Dave |
Evil Genius
Couldn't be that hard to build one. Lipo 8-10S or larger cells in a series parallel arrangement. RV Small Lipo batteries or an RV Lipo battery off amazon too. Think Outside the charge Box.
Life is a big ocean to swim in. Wag more, bark less.
What the heck is a "series parallel" arrangement. Are you doing series in sets and then paralleling them for added amp hours?
Evil Genius
Yes. (2) 6 VDC in series. Then add another pair in parallel. Lots of reserve that way.
Platinum Member
I do have one of these digital battery testers, it can measure capacity and internal resistance of a 12v battery, so I can tell when a battery is reaching end of life. https://a.co/d/5RpXwuj
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I have an old version of one of these:
https://www.schumacherelectric.com/products/categories/battery-chargers/
1996 FJ80. |
Platinum Member
On my truck and boat I also replaced one of the cigarette lighters with a USB jack voltmeter: https://a.co/d/hTZ0FC0
I have a volt meter but that only tells me if the alternator is functioning properly. The car battery tester you posted tells us lots more?
Paul, I have this old thing bought used back in my college days when I was poor. Had to buy used batteries to survive. That old charger still saves my bacon which it did last Saturday morning. I think the newer more sophisticated batteries and that old charger do not like each other.
disband
just buy 2 new batteries alligator arms. a diesel takes a ton of current to get underway and a jumper box is like a band aid for an alligator bite. see what I did there?
my 08 DM batteries lasted 12 years with trickle charging them when it's stay parked for a while towards the end. if your volt gauge is reading below 15 when running they are done.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
