Guest
Posts: n/a
Babybackbakedbeans
After marinating in Lea & Perrins, minced garlic, salt, pepper, and Snyder's rub overnight, the ribs go onto the grille at 5am, to smoke at the lowest setting for 3 hours.
Basting with Lea & Perrins every 20 minutes so meat does not dry out during smoking. 1 lb chopped bacon, yellow onion, sliced garlic get sauteed together for the beans. Also add ketchup, hot sauce, mustard powder, salt, pepper. Dried beans soaked overnight in saltwater. Added to bacon/onion/garlic mixture. After three hours of smoking, ribs wrapped in foil, and beans are added to grille. Wrapping in foil helps render out the fat from the meat, reducing greasiness. Ribs unwrapped at 4pm, after 11 hours, heat increased from 180 to 400 degrees, sauce added. I don't like to oversauce--serve most on the side. Stubbs Sweet Heat is my family's consensus. No leftovers. |
Wow! You should have made more so there would be some leftovers.
Marv Evans '69 911E |
Wow, looked like vultures picked over the bones.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Pics of mac and cheese or it didn't happen.
Great looking meal!
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
A Man of Wealth and Taste
No wonder it took you 11 hours to cook those ribs with you opening the smoke chamber every 20 minutes..
Must have cost a fortune in Briquets to fuel that thin tin smoker you are running for 11 hours. Did ja at least throw a few soaked wood chips on da fire? To impart some smoke flavor. Last edited by tabs; 08-19-2019 at 04:11 AM.. |
looks fantastic!
Tru6 Restoration & Design |
And you are running a Lodge cast iron skillet..not even a Griswald or Wagner.
Brew Master
Looks great! You went all in on the baked beans man!
Just a suggestion... lookup 2-2-1 ribs. 5 hours and they are done to perfection cooking at around 225-250. 2 hours on smoke, 2 hours in a foil wrap, 1 hour back on heat to firm up.
Nick |
Guest
Posts: n/a
You could have held a gun to my head and I couldn't tell you what type of skillet it was. |
Guest
Posts: n/a
As I was putting the ribs on Saturday morning, my neighbor was headed out for salmon. About midday he brought this guy over. Cooked last night in the Traeger, fed six.
Similar quantity of leftovers at the end. Between my ribs and his salmon, we have a very fine mutually beneficial exchange system established. |
Anyway, how was it?
Next time use a coffee rub on pork or need.
Guest
Posts: n/a
Senior Member
Stubbs is indeed best.
Y-U-M, Terry. I thought I eat well. You eat WELL.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
You really shouldn’t cook ribs that long. Half that time is plenty, if you do it right. 11 hours is what you might consider appropriate for an entire shoulder.
Guest
Posts: n/a
With ribs, it seems to be all about the heat and the rendering. Don't want them greasy, and don't want them to be pork jerky on a stick either. |
Brew Master
How long did you do the Salmon? I've always done fillets. Tried cold smoking but the cold smoke generator I bought was a bit tough to work with.
Nick |
AutoBahned
more meat, less beans
He probably wasn't wearing his Italian loafers and Dragon-Azzed jeans either!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
