-   -   Fix crack in helicopter Bubble ? (http://forums.pelicanparts.com/off-topic-discussions/1161777-fix-crack-helicopter-bubble.html)
afterburn 549 05-17-2024 01:57 PM
Turns out to be more of a language and more linguistics than ever intended.
I will just find a new or used bubble.
masraum 05-17-2024 02:04 PM
:D
https://cdn.asotvinc.com/pimg/5DF60E...270CF4C2F8.jpg
Seahawk 05-17-2024 02:13 PM
PM me some pics.
908/930 05-17-2024 02:45 PM
What material is it? If it is acrylic look at products from Weld-on. Need good ventilation. Weld on 16 is a pretty good filler that I have used in the past.. Weld on 40 or 42 are two part filler but I have never used.
Zeke 05-17-2024 03:09 PM
Weldon is the word.
RNajarian 05-17-2024 04:23 PM
What make and model of whirley bird is it ?
RNajarian 05-17-2024 04:32 PM
Thanks for the info.
I hope the term “whirley bird” isn’t an inappropriate term for a helicopter pilot. I’m a fixed wing guy.
afterburn 549 05-17-2024 04:36 PM
Hiller Raven OH 12 C (UH23C) (OH23)-All the same Bubble
afterburn 549 05-17-2024 04:37 PM
There was a show on TV called The Whirly Birds Late 50s So I guess it is appropriate.
Steve Carlton 05-17-2024 04:52 PM
What did you fly in the Air Cavalry?
908/930 05-17-2024 05:05 PM
Weld-on #4 is just a solvent, good for overlap bonds, I do not think it is what you want to use. The #16 is thicker it has some filler material in it, same solvent base.
908/930 05-17-2024 05:43 PM
I don't think you will need to drill if you can bond it properly, was the stress that caused the crack internal? With the #4 it will flow through just about any space like water but you need to be able to force it together to get the material to bond. How long is the crack and how thick is the material?
Seahawk 05-18-2024 05:09 AM
For AB:
http://forums.pelicanparts.com/uploa...1716034117.jpg
I know a lot of Helo Depot folks and they may have some suggestions. I'll need pictures and what it is made of and age since I have no idea how to repair - hopefully they may be able to help.
afterburn 549 05-18-2024 05:30 AM
Will be pix here in about an hour
Thanx for the Baby Huey pic, LOL
In the early morning mist a roll with the wrist
A push on the button
Things came into motion we started to lift
In the early morning mist the sun not quite up
Headed for another LZ
another insertion or pickup
It was always all the same dodging the green tracers
the pounding of the blades
in the mist blood and rain
Now to wash it all the red stains
masraum 05-18-2024 07:32 AM
Yikes, those look like big cracks that need to be fixed. Seems like replacement would be ideal except to your wallet.
afterburn 549 05-18-2024 09:33 AM
I would replace it, if I could find the parts.
Seahawk 05-18-2024 10:23 AM
What year is your helicopter? I know it is a Hiller Raven, but what year and when was the last time it flew?
The initial response from the folks I know that do this was not positive. If you are flying a certified aircraft, the manufacturer is the deciding authority on, trust me on this, cracks in canopy bubbles and doors and the required fixes to maintain that certification. An AP will insist on that before signing off on the repair. Any fix must have a basis in the certification.
I really want to help you with this. So, what manuals do you have from Hiller? That was their first question.
Let's start here: https://hilleraircraftcorporation.com/all-model-revisions-publication-status
Or here: https://www.aircraft-reports.com/hiller-hte-h-23-oh-23-raven-helicopter-manuals-bundle-on-dvd-or-download/
https://www.eflightmanuals.com/ITEM_EFM/SDETAIL_EFM.asp?mID=1151
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2499334.m570.l1313&_nkw= hiller+raven+canopy&_sacat=26435
If you don't want my help, I understand. Remember I have a lot of hours and factory time in helos...you may need help getting an airworthiness certificate. I could be wrong.
Let me know.
908/930 05-18-2024 10:27 AM
Do you happen to own a vacuum pump? Do you have a place to purchase a small piece of acrylic to practice on, any sign shops nearby?
What Seahawk said could change things.
Seahawk 05-18-2024 10:42 AM
I would call them:
https://hilleraircraftcorporation.com/what-we-do
Hiller Aircraft Corporation
925 ‘M’ St
Firebaugh CA, 93622
Info@hilleraircraft.com
(559) 659-5959
Again, I know how hard this is...we stopped doing FAA repairs because, and I do not disagree at all with their standards, keeping our quals for the FAA were onerous.
Arizona_928 05-18-2024 11:21 AM
When one is repairing an aircraft before the existence of the FAA… The thought of regulation overreach comes to mind…
There’s a lot of static displays around, maybe reach out for a trade on a non cracked bubble.
