Literally Stuck: Rebuilding a Vintage Girling Brake Caliper - Pic
Hey Guys - I am rebuilding the rear Girling caliper (1972 vintage). The piston is completely frozen in the bore.
I tried using the piston removal slide hammer tool (seen in the picture) with heat and zero luck. Any suggestions?? Thanks, Yasin
Ole Skool - wouldn't have it any other way |
Soak it in PB Blaster and use air to blow the piston out?
Do you want to salvage the piston? I was thinking maybe use heat and PB Blaster with a pipe wrench or similar to break it free. Is it square in the bore? |
The machinists in me says to put it on a mill and bore it out of course no more piston but a reusable caliper
I've heard about pumping grease in but have'nt tried it.
^^^ I used a grease gun once, it worked but was extremely slow. And very messy. Someday I'll build a proper hydraulic system with a brake pedal to push pistons out easily. Been very lucky with air on Turbo calipers.
Tru6 Restoration & Design |
Any chance you can press it in to break the bond?
What about an ultrasound cleaner? |
Navin Johnson
Use a vice or c-clamp and see if you can move the piston in, you'll know if it is moveable or totally frozen... If you can move it, use a grease gun, or hook it up to a brake system and use the brake pedal to force the piston out..
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Almost Banned Once
(Obvious but...To use grease or air pressure you'd have to reassemble two halves)
- Peter |
A puller...to "pull" the caliper (held in a vise) through the piston? Actually then pushing with the puller screw? Good soaking with PB blaster first...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Bland
What penetrants have you tried?
You need to hit it with pressure. I hope the heat you have applied hasn’t damaged the aluminum.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Soak in salted vinegar a few days?
I’ve done it and it’s a messy process but it works.
dolor et pavor Copyright |
I used a hand held hydraulic pump used for various jaws of life tools, 10000 psi , worked great , just walked it out.
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Thanks guys.
I soaked it again last night with generous amounts of PB Blaster and then put a pair of vice grips on the piston and worked it back and forth and finally walked it out. The vice grips of course marred the piston, which is OK as I have a new piston and re-build kit. I appreciate the help! Yasin
