-   -   Transformer/Voltage/Amperage/Gauge? (http://forums.pelicanparts.com/off-topic-discussions/1163285-transformer-voltage-amperage-gauge.html)
RNajarian 06-20-2024 10:42 PM
I am adding a security camera to my house. The current camera is on the corner of my house pointing north. I want to add the same type of camera pointing east located on the corner of the house 3 inches from the original camera.
The cameras came with a 5v 1.2 A transformer. Each camera works with the current wiring. I spliced into the wiring and added a second plug for the second camera.
I replaced the original transformer (5v 1.2 A) with a new one 5v 3.0 A. With both camera’s plugged in only one camera works at an time.Each connection delivers 5.01 volts. Essentially only one camera works at a time with the new transformer.
The only thing I can think is the problem is the gauge of the existing wiring is wrong and affecting the electrical current.
Any ideas ?
Thanks in advance.
Bill Douglas 06-21-2024 01:19 AM
I'm thinking both cameras are using the same radio frequency (something like 2.4GHz) and only one can use it at one time.
RNajarian 06-21-2024 07:22 AM
That’s a good suggestion Bill, but these camera are WiFi at different Internet addresses (192.162.0.101). I’ve got 6 other WiFi cameras hooked up with no interference.
I ended up running a second wire the same gauge as the original wiring from the second camera spliced into to the original 5 v 1.2A transformer.
Both cameras work. So the issue was the thickness of the wire.
So thanks for listening everyone
MBAtarga 06-21-2024 10:37 AM
How long was the wire to the cameras? 1A per camera is quite a bit of juice.
RNajarian 06-21-2024 10:49 AM
4 1/2 yards
Bill Douglas 06-21-2024 12:39 PM
Good thinking! I'm pleased you got it sorted.
Both GF at her house, and me at my small commercial unit, are looking into cameras. She is thinking of a Eufy setup and I'm looking at Ubiquiti UniFi cameras. Do you have any thoughts regarding these or a better option?
Rusty Heap 06-22-2024 08:00 AM
http://forums.pelicanparts.com/uploa...1719068397.jpg
