A question about car batteries…
The traction control and brake indicators on my instrument cluster have turned on, on my 05 BMW 330. Using INPA, I have a few codes that I’m working on, one of which is electrical (overcharging?).
I checked my 51R battery with the engine off and I got 13.17v and with it running at idle, I get 14.00. How is it my battery is registering 13.17v? Shouldn’t it be 12.6 with no load and the engine off? Edit: how is it my ABS – DSC system voltage is seeing higher than 18v If I’m seeing 14v at the battery at idle? Codes below: 5DF7 ABS-DSC: System voltage > 18 volts dsc_mk60 Stability system MK60 5D97 ABS-DSC: DSC sensor, voltage supply dsc_mk60 Stability system MK60 5E43 ABS-DSC: Steering angle sensor, internal dsc_mk60 Stability system MK60 5E24 ABS-DSC: Pressure sensor dsc_mk60 Stability system MK60 Last edited by A930Rocket; 08-12-2024 at 03:05 PM.. |
Do you have a dedicated battery tester or are you using a multimeter? I just changed the H7 in my 997 this weekend because the car just sits and I didn't leave the maintainer on it. My tester was getting weird reading, so I said F it and got a new battery. Everything good now!
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
I’m using a multimeter.
You can put a "surface charge" on a battery. If you charge a battery at 13.8V for a bit, it'll show near 13.8V immediately after taking it off of the charger. I don't know how long it takes for that to normalize, if it's a matter of minutes or hours or what.
When you load test a battery, that'll kill a surface charge pretty quick. If you have a load tester that simulates starting a car, one or two tests will normalize the battery (assuming no charging is happening). I wish cars still came with real Voltmeters, Oil Press, and Temp (water or oil) gauges. I'd pay $300 to swap out my gauge cluster for one that replaces the useless analog speedo with oil press, oil temp, and volts gauges
Steve nailed it. Dittoes on the gauges...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I had it on my battery maintainer, so maybe that’s it?
I’ll leave it off and test it again tomorrow. I installed a dedicated water temp, oil temp and oil pressure gauge on this car. |
Sweet! I've installed gauges in lots of cars over the years, even basic, pedestrian cars. My Boxster's got a water temp gauge, a tach, and 2 speedos (digital and analog). It would be fairly easy to install a voltmeter if I could find a good place to put the gauge. There's nothing to a Voltmeter. Installing oil pressure is much more of a pain. My car has an idiot light, so I'd have to install a T to keep the idiot light and have the pressure gauge. I believe some folks have installed a pressure gauge in the wart on the dash after taking out the stopwatch which makes a ton of sense. I honestly don't trust that the water temp gauge is undamped. I think that a lot of gauges these days are heavily damped. When miatas first came out they had a real, honest temp and oil pressure gauges. Then mazda made them non-linear and heavily damped. So the temp gauge, for instance would read cold - middle/good - too hot. I suspect lots of companies have done that because it saves them lots of time and money. I really miss the gauges out of my old '88. They were all accurate. I could tell the temp, oil pressure, oil level, etc... all at a glance.
Same faults (DSC and Brake light on) in a recently acquired 2001 330CI. If you'll search the symptoms on youtube, you'll find a video of a fellow discussing the very issue and apparently (especially on the convertibles) there is a wiring connector near the front of the drivers seat that can corrode/bad connection and cause the issue. I haven't dug into it yet.
The E46 water temperature is the same way. It sits at the 12 o’clock position but there is a temperature zone of so many degrees. Then, if the engines getting hot, it jumps from normal to hot. You need to be prepared to shut it down quickly.
I would connect a decent voltmeter to the battery, set it to 'peak hold', and drive the piss out of your car for ten minutes. Either you really are producing a very high voltage from your alternator, or the cars voltage sensor has crapped out...
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Will this work? Can't scroll down past the BMW gauges pic. This is a test...
