-   -   How Are Tacomas to DIY? (http://forums.pelicanparts.com/off-topic-discussions/1166452-how-tacomas-diy.html)
OK-944 09-02-2024 04:59 AM
Thinking about a used Tacoma - 2012-ish, manual trans, extra or crew cab, either four or six cylinder.
Question - how are these trucks for "weekend DIY Guys" like myself?
Thinking of what I've done with my 944's (engine/brake/suspension/power steering rebuilds...seat/dashboard reupholstery, etc.) how does this experience translate to the "Tacoma Realm?"
Also - I'm of two minds about going with a four vs six cylinder Taco...thinking of the smaller engine as perhaps more "bullet proof," and easier to work on/rebuild - but otherwise everything and everybody keeps pointing to the six as way more useful/practical.
Comments? Thanks!
craigster59 09-02-2024 05:52 AM
People like the 4 cylinder 22R engine on the older Tacomas. I see 2 older Tacomas each towing a Tacoma, both beds filled with body and engine parts 2-3 times a month heading south for Mexico. They love them down there.
Having owned both 4 and 6 cylinder I would go with 6 as that engine can even seem anemic at times. Maintenance will be minimal, just standard stuff like oil and brakes. Both easy for a DIY guy.
Bob Kontak 09-02-2024 06:02 AM
+1
With respect to brakes there is probably a proportioning valve on the driver's side rear way up top in the brake line(s). Find that and know it can be bled. It's up top so air bubbles can get removed through its bleeder. It sounds like an insignificant factoid until you spend a weekend looking for why the pedal is spongy.
Pazuzu 09-02-2024 07:41 AM
If it's anything like my 2011 Nissan Frontier, then the 5-speed will wake up the 4 banger just fine. I'm still surprised how quick my truck is because the 5-speed lets you wring the gears out a bit more. I would expect a slushbox on the 4 cylinder of either truck would make it pretty slow.
That being said, consider the Frontier. I've been blown away with it over 3 years, it's the smoothest manual transmission I've ever driven, feels sturdy, drives great, comfortable. Turns like a fat pig because the steering stops are poorly designed. I was a true blue Toyota guy for many many years, I wouldn't pick a Taco over this.
Dpmulvan 09-02-2024 07:47 AM
Comments? Thanks!
Owned Toyotas forever, I’d get the six, you can haul a dskh and 6 fighters up a mountain ( kidding). Seriously other than brakes, wheel bearings not much goes wrong.
Well engineered, easy to work on. Might just need something like a blue driver to reset abs, traction et after a brake bleed if you go with newer models.
Bob Kontak 09-02-2024 08:37 AM
Get the six.
I would maybe not say easy. I would say do-able. The engineering for durability makes it a bit more tedious but by no means a show stopper.
I had to change out the rusted front bumper bar on a 2004. The amount of fasteners was insane. Bolted upwards and downwards. Brackets, etc compared to the one piece "plastic" nose. It was integral to the front end and not a piece of fascia. Impressive but annoying given the rust belt.
Not the truck but showing bumper. (good looking truck but I think the 2005 and on are built for full size human beings - nice way to say kinda small for a fat guy)
http://forums.pelicanparts.com/uploa...1725291246.jpg
Seahawk 09-02-2024 08:38 AM
Owned Toyotas forever, I’d get the six, you can haul a dskh and 6 fighters up a mountain ( kidding). Seriously other than brakes, wheel bearings not much goes wrong...
I concur on the six cylinder.
Routine maintenance on the SR-5 and then my newer Tacoma was a breeze.
I'm sure you have looked around, but my son used this site when he drove the Tacoma:
https://www.tacomaworld.com/
look 171 09-02-2024 12:11 PM
You need to work on those? Why? They never break.
Get the 6 for our American Hwy if not the 4 is Ok too but lack a bit of real oomph when needed going up the long grades out here in the west still, you will be fine. I have had those old 22RE engines in many of my cars and trucks and not a real issue just don't load them up with 3000 lbs of bricks and expect it go fly up the mountain .
Pazuzu 09-02-2024 01:21 PM
The Tacomas never had the 22RE, they have the much stronger and more advanced 2.7L engine.
3rd_gear_Ted 09-02-2024 01:23 PM
I have spoken to the I-10 Toyota guys a couple of times.
They have a network of west coast sources for Toyota parts and older trucks.
They localize all the stuff to LA and hit the road. One operable truck tows the inoperable truck, both packed full. sometimes three pairs in a caravan.
When they hit the Mex border its 5 days driving in only daylight to Guatemala.
I have two 22R project trucks @ my AZ home. I get notes on my gate a lot.
Thinking of a Somalia style urban assault vehicle.
Need a Browning 50 Cal?
Hello FISA just kidding;)
WPOZZZ 09-02-2024 02:47 PM
Very timely thread as I'm picking mine up in a couple hours. Very high mileage 2020, but maintained. I just need to do some cosmetics to make it more presentable. I remember my 01 4Runner was a PITA to remove the oil filter without making a mess. I hope that is improved.
look 171 09-02-2024 02:58 PM
Ishould clarify. My old trucks
look 171 09-02-2024 03:02 PM
180 k miles isn't real high mileage in those vehicles. Over 300 is really high mileage. AT 180k, suspension rubber parts needs to go. Replace with factory parts, you have another 150k on them. I am not sure if the strawberry mile shake issue with the radiator has been fixed. One some of the older V6, late 90- 2000s. The trans cooler leaks into the radiator and it mixes with the coolant. Not good, every 100k, we change out the rad.
flatbutt 09-02-2024 04:35 PM
I had a little over 225K on my '06 4 cyl Taco when the frame finally rusted out. Never a serious issue. The worst was a cracked leaf spring and Toyota replaced both stacks at no cost to me.
Rusty Heap 09-03-2024 11:29 AM
I'd love to own a Tacoma but the A-pillar is raked WAYYYYYY too far back for a limited headroom height and line of site out of windshield. ICKY
Bob Kontak 09-04-2024 05:46 AM
<iframe width="467" height="831" src="https://www.youtube.com/embed/_kXiD2AtH2g" title="Toyota knew how it's done" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
flatbutt 09-05-2024 05:23 AM
That's hilarious!
911 Rod 09-05-2024 06:47 AM
^^^ Ha! I didn't see that coming!
If it's anything like my 16 Tundra, it's easy to work on.
Like an old 911, everything just makes sense.
But there's rust .....
HobieMarty 09-05-2024 07:05 AM
It's a Toyota, so yeah, it's pretty easy to work on.
I want an older Tacoma also. Guy on my street has an older one like the model pictured a few posts up. It is silver, is a crew cab, and just sits on the street because he has a newer one. I want that truck!!! Maybe I should stroll down there and ask if he wants to sell it. Lol.
