Banned
Is this fixable?
Or maybe a better question, what is the best strategy to fix this? Epoxy is the obvious answer, so what is the best epoxy to use? I'm guessing that I should epoxy and sand/grind it down for paint, maybe epoxy a brace or extra layer underneath?
For anyone poised to ask why I don't just find a good used bumper, the answer is that they are unobtainable for this car, a Mercedes-Benz w124 wagon. If you can find one, they usually have damage and are ~$1000. Mine is fine other than this cracked part. I want to fix it, entire car and bumpers/cladding is getting painted. Thanks as always! ![]() ![]()
I think that is heat weldable material, I would still reinforce the back with a single layer of fiber glass and epoxy. Look at hot air welding, really need to identify what material it is first, I'm thinking PVC but not sure.
87 930, Last edited by 908/930; 09-25-2024 at 11:34 AM.. |
SEM MiniMax works well, just make sure that the cartridges flow the mix at the proper rate.
It would help if you could bring the pieces closer together somehow-even with gorilla tape and do the repair 1/2 at a time. Or better yet, remove the bumper cover and do it off of the actual metal impact bar, then reinstall. I recently had to do this with a r129 that had damage to the lower integral valence/spoiler. One of the comments to the ad is interesting, suggests using drywall mesh tape behind the repair. Great idea.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) Last edited by greglepore; 09-25-2024 at 11:36 AM.. |
unsafe at any speed
Plastic welder, if you take it off and look on the inside there will be a stamp whether it's poly propylene, ABS, PVC... You can can buy the correct filler rod to weld it. I have a welder I got from Matco tools, that I use for motorcycle plastic welding... Basically a large soldering gun with different heat settings for whatever plastic you are welding. You may have a local auto body shop that will weld it for you.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
There are plenty of plastic bumper and body adhesives on the market to choose from. A layer of glass will help as 908 says.
I've used 3M's panel bonding adhesive for steel and it's phenomenal. They must have a version for plastic. What year is the car?
Tru6 Restoration & Design |
Been here a while
if you can get behind it, reinforce with mesh, fiberglass or steel screen material and some epoxy, it won't ever break there again.
looking for 1972 911t motor XR584, S/N 6121622 |
Hot staples, steel wool and epoxy/fibreglass resin in the back.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Parrothead member
On my 944 air dam, I used the harbor freight plastic welder. Worked great. I heated up piece of metal screen and melted it into the back of the crack.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." Last edited by VINMAN; 09-25-2024 at 02:43 PM.. |
Banned
Thanks, guys. I’ll definitely be removing the bumper to repair it.
The car is a 1992 although the rear bumper is the same for all w124 wagons. |
That thing's in so many pieces...
I'd keep looking for another one. Hard to find, maybe. But nothing's impossible. |
Retired Member
I would tape over the damaged area, remove the bumper then lay fiberglass on the inside to offer some strength.
Hopefully it will offer enough strength so you then can apply filler to the outside of the bumper and reshape. It worked for me for a NLA dash piece on my C6
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Anyway, that's an easy fix though time consuming to get back to original.
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 09-25-2024 at 04:51 PM.. |
Banned
The '80s cars ARE different and the early '90s cars are different from the '80s cars and the last cars. The '94/'95 w124 cars like the one pictured above have different hoods/grilles/headlights and of course the new at the time M104 engine. The 1986-'92 cars had the M103 engine and wagons began in 1987 with the *one year only* diesel wagon, (OM603 6-cylinder diesel), then from '88-on they were gas only for wagons in the USA.
Diesels were of course available in sedans here in '87 and then in scattered years in the '90s. I also have a '95 w124 diesel sedan, a one year only car with that body/engine combo. |
I had one in same color as Shaun's. I gave it to a needy friend ( local bike shop wrench) when I bought my s420. He and his infant were rearended at a light by a full sized pickup going maybe 35-40. Car likely saved them.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Behind the Sun
Buy a new bumper yours is gone. 554 is not a bad price Duck tape it if you want to save money |
Banned
There are a few on eBay when I looked yesterday. There are several good W124 forums too.
LOL on the bumper, likely the only part of that that would buff out. I forget-did you fall asleep?
Yup, fell asleep after many sleepless nights and then driving back and forth and back and forth to NYC.
