-   -   does this exist? hand pump/bellows (http://forums.pelicanparts.com/off-topic-discussions/1168676-does-exist-hand-pump-bellows.html)
id10t 10-11-2024 08:19 AM
So my new muzzle loader - a nice TC White Mountain Carbine - has this issue..
From clean, I can load the first two shots fine but then the third is extremely hard. Easy - run a nylon brus up/down bore a few times, invert and knock the crud out. Problem is then the dogleg flash channel gets clogged and a nipple pick wont clear it so I have to pull the nipple and put a bit of powder directly behind as a booster charge
A blip of canned air clears it or at least seems to - will test that today after work. If that works though then I would like a bicycle pump or hand bellows or something that can give me a quick very directed 1/2cu ft or so of air
The canned air I have ought to get me thru a few range sessions but since my other TC is likely to do the same thing I would rather not depend on the canned air
(not worried about hunting since that will be a shot on a clean system)
Ideas?
Scott Douglas 10-11-2024 09:11 AM
Only thing I can think of is a lens blower for cameras, but that's not going to give you 1/2 cu ft of air volume.
id10t 10-11-2024 12:36 PM
I'm sure the actual volume I need is much smaller, but I have no idea as to what would be the minimal amount needed....
911boost 10-11-2024 12:51 PM
Do a search for squeezeable air pump. That may give you what you need in a compact package.
fanaudical 10-11-2024 02:42 PM
Wacky idea - Balloon animal pump. You might have to slip a piece of hose over the spout to seal on the muzzle (or adapt something to blow through the nipple if you're doing that).
id10t 10-11-2024 02:58 PM
1/4" airline tubing fits fine ;)
pwd72s 10-11-2024 03:30 PM
something like this?
https://www.ebay.com/itm/400810267845?_trkparms=amclksrc%3DITM%26aid%3D1110 006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D26418 4%26meid%3D9cc621281e40419b9c1cfe54e2eb1efb%26pid% 3D101875%26rk%3D1%26rkt%3D4%26sd%3D386986694799%26 itm%3D400810267845%26pmt%3D1%26noa%3D0%26pg%3D2332 490%26algv%3DSimVIDwebV3WithCPCExpansion%26brand%3 DHorizon&_trksid=p2332490.c101875.m1851&itmprp=cks um%3A4008102678459cc621281e40419b9c1cfe54e2eb1efb% 7Cenc%3AAQAJAAABAKAOBbj8c9I6eO4vPyI9FfMl8NhNqsULUU 1TfDUZ7khlYBkeXzqwA1xZ3jdKR6GriZMYVTvGY3%252FwBZJy LlQNp0hIcZjHSD7Lhof2z6Rox77wviyfdEXnD1VxnNsn1yAHW4 rdlBuRfNmSybqvXhB%252FeHwlGqx4iXt1qGOo%252BEID1YfF irya33hZQ8DN21hF8HgIjahlsr6SFOphdEqlHEB04idTytNohn Eyo9F8YfPvE%252FDecfY1fW0kGd%252FQDuwhnmG3DveZlgc6 ZfaGu1kIjpoSj9JKImjIb5XHTMjiCTDvlLLrfc7UCKQyy5fimC cr%252FXd%252B7SMGx2bCOSFn7W2Okad27yQ%253D%7Campid %3APL_CLK%7Cclp%3A2332490&itmmeta=01J9YV3C256KQZJS BA880G6X38
herr_oberst 10-11-2024 04:06 PM
http://forums.pelicanparts.com/uploa...1728687995.jpg
Tishabet 10-11-2024 04:10 PM
if you really need that much volume maybe retrofit a bag valve mask aka ambubag? These are cheap/disposable items.
https://media.istockphoto.com/id/862...YI_3QhdcgxxfY=
id10t 10-11-2024 04:34 PM
And to think I stopped working in central supply for a hospital 26 yeas ago ... One of those big massive syringes we used for lavage treatments on wounds may work...
