id10t's Avatar
does this exist? hand pump/bellows
So my new muzzle loader - a nice TC White Mountain Carbine - has this issue..
From clean, I can load the first two shots fine but then the third is extremely hard. Easy - run a nylon brus up/down bore a few times, invert and knock the crud out. Problem is then the dogleg flash channel gets clogged and a nipple pick wont clear it so I have to pull the nipple and put a bit of powder directly behind as a booster charge
A blip of canned air clears it or at least seems to - will test that today after work. If that works though then I would like a bicycle pump or hand bellows or something that can give me a quick very directed 1/2cu ft or so of air
The canned air I have ought to get me thru a few range sessions but since my other TC is likely to do the same thing I would rather not depend on the canned air
(not worried about hunting since that will be a shot on a clean system)
Ideas?
Old 10-11-2024, 08:19 AM
Only thing I can think of is a lens blower for cameras, but that's not going to give you 1/2 cu ft of air volume.
Scott
'78 SC mit Sportomatic - Sold
Old 10-11-2024, 09:11 AM
id10t's Avatar
I'm sure the actual volume I need is much smaller, but I have no idea as to what would be the minimal amount needed....
Old 10-11-2024, 12:36 PM
Do a search for squeezeable air pump. That may give you what you need in a compact package.
Old 10-11-2024, 12:51 PM
Wacky idea - Balloon animal pump. You might have to slip a piece of hose over the spout to seal on the muzzle (or adapt something to blow through the nipple if you're doing that).
Old 10-11-2024, 02:42 PM
id10t's Avatar
1/4" airline tubing fits fine
Old 10-11-2024, 02:58 PM
Model Citizen
herr_oberst's Avatar
Old 10-11-2024, 04:06 PM
Feelin' Solexy
Tishabet's Avatar
if you really need that much volume maybe retrofit a bag valve mask aka ambubag? These are cheap/disposable items.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 10-11-2024, 04:10 PM
id10t's Avatar
And to think I stopped working in central supply for a hospital 26 yeas ago ... One of those big massive syringes we used for lavage treatments on wounds may work...
Old 10-11-2024, 04:34 PM
