Porsche Al allen drain plug - impact?
I went to change the oil on the Boxster for the first time. The drain plug seems REALLY tight, and the back of my mind had UncleBilly's thread about getting out a stripped drain plug.
What I was using was an 8mm allen wrench (not socket and ratchet, since I ended up not having an 8mm hex socket). It felt like the allen wrench was "giving" a bit, so I stopped pulling. I tried tapping on the Allen wrench with a tool as a makeshift impact, but working under the car as I was, I didn't have the necessary space for a good effort. I have 2 thoughts 1 - pay someone to do the change one more time so it's their problem 2 - get a little 3/8" battery powered impact and 8mm hex socket to get the the thing out myself Thoughts on something better that I may have missed?
Heat. A little mapp gas torch should loosen it up. Heat the sump around the plug, not the plug.
Keep talking, Im gonna put you in the trunk. Last edited by JackDidley; 10-20-2024 at 12:26 PM.. |
You do not have permissi
Get a new plug before.
Sound like they are now a wear item.
Meanwhile other things are still happening. |
Yep, I've already got a new plug and crush washer.
You mean something like this?
Is there room to get a bite on the OD of the plug with a small pipe wrench?
87 930, |
Yes. I'd be tempted to just take it to your service guy for this oil change though.
Keep talking, Im gonna put you in the trunk. |
After you get the drain plug out, use this (find the one for your Cayman). Problem solved. Not sure if it will stick out of the bottom of the oil pan, but I put one in my kid's $Runner. The drain is well up in there under skid plate with an access hole. Connect a vinyl tube to a jig, let it drain. No mess. Drains a bit slower then having the drain plug open, but it allows him to finish his ice-cream.
https://www.amazon.com/Fumoto-F-104-LC-10-Lever-Engine/dp/B07D9D6VDF/ref=asc_df_B07D9D6VDF/?tag=hyprod-20&linkCode=df0&hvadid=693585715857&hvpos=&hvnetw=g&hvrand=11545022409465309270&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9030984&hvtargid=pla-570196057325&psc=1&mcid=fc1fb3c4c08c39b083d0faf8bb7f9ece |
Yeah, but that's a huge pain too. My service guy is 80 miles away. Working out the logistics of getting the car there, and then picking it up again (and not rushing the guy) sucks. That's why I'm trying to do the oil change myself (for the first time). The last time, I took it to a shop that's only 42 miles away (that has a good rep). They seemed to do a good job, except that now I've got this plug that I'm worried about removing, and I'm not sure if it's just one of those things or due to something that the last guys did (I don't trust most mechanics any further than I could throw one).
Evil Genius
Just did an oil change, it's a torx bit. I had a tool from the 1980's, a VW Bug CV Joint bit fits perfect.
want me to loan you mine, I'll ship.
Life is a big ocean to swim in. Wag more, bark less.
Evil Genius
I'd post a picture but stupid pelican takes 18 minutes to upload a 2 meg file at times.
This is interesting, as I just topped off the differential in my 330 yesterday. I had installed new plugs when I installed the differential a couple years ago. I ended up having to modify/grind a 9/16 Allen to fit properly. I don’t know what I used to tighten it back when…
Do you have a larger hex, that you could modify to fit better? It’s hard to tell on my phone, is it a torx or hex. I have to look closer at mine next time. |
What the hell was wrong with a steel nut like all auto mfg used in the pass? Fancy Torx and all the bs only means we have to buy from them. Is there an after market simple drain plug from an foreign auto parts house that fits? I am not sure and have never looked into it. Too low for my fat ass to crawl under to see.
![]() That's definitely not what my plug is.
This style extractor will get it out, done many this way that were previously stripped or overtorqued....
![]() Never had this method fail to remove a messed up plug. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I bought the top one, "Febi Bilstein," for $7. I considered one of the models with magnets (Rennline or LN Eng) @ 4-5x the cost, but then I'd had to have to replace those with every oil change, like I'm planning to do with the cheap ones. You can bet your aß that I'll be using a torque wrench to get the plug to 37ftlbs (and the oil filter cover to 19ftlbs) ![]()
Why not the stainless or a steel one that can take a bit of abuse from your wrench? If the one you bought alum?
