Anyone using a power bank?
Most of my motorcycles are in a couple storage units right now.
Unfortunately there's no power in the units for a battery tender nor does the owner allow a solar panel charger. Usually I rotate riding them often enough I can bring them home and charge the battery overnight and then rotate to the next one. Most have battery tender harnesses on them so very easy to do this. I also have two cars in storage units with battery disconnects for the negative battery posts. They work fantastic - both cars started right up for me today. But most of my bikes didn't because the batteries didn't have enough juice. Do I install disconnects for the motorcycle batteries - it would have to be one on a loom to make it easier to access the switch. Or buy a power bank and hook up a battery tender to them on a rotating basis. The disconnect, if it worked, would be less hassle. Looking for any suggestions and input here....thanks! And before you say I should be riding more often...yeah you're right. A broken rib, hurricane, and family stuff has a way of slowing things up in that department. Hoping to get back on track soon though. Thanks! |
Found a YT video showing how a power bank would work for my application.......pretty nifty!
<iframe width="718" height="404" src="https://www.youtube.com/embed/3jdEPldvveg" title="Charging a motorcycle battery with a Jackery portable generator @JackeryInc #jackery #streetbob" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe> |
Pull the batteries and take them home?
Battery pack looks easier. Maybe two and swap them out occasionally?
The owner won't allow a solar panel but a battery pack is OK?
Anything smaller than that wouldn't really be practical - nor allowed. I really think the power bank is the answer here.....just curious if others are using one and what their experiences with them is..... |
How about just carrying a lithium jump box. Hook it up and start the bike....ride.
Is the battery pack meant to do this (didn't watch the video as I'm at work)
Some go boom |
Battery inverters are not practical IMO. If you want to spend that kind of money feel free.
I would buy the jump box, or a good sized AGM car/truck battery and connect that to your bikes on a rotating basis. |
Do motorcycles have much parasitic draw? In my experience batteries maintain their charge pretty long when completely disconnected, I think a disconnect switch maybe your easiest bet.
I pull all my batteries for storage and assuring a good connections upon reinstall.
Batteries store well but connection corrosion never stops. Also acts as a theft deterrent in rural AZ. |
I just got an 1200 watt Ecoflow Power bank with a 120W solar panel. I'll probably use this in place of my gas generator most of the time during power outages. I haven't put it thru a real test yet, but it seems impressive so far and could easily run a trickle charger for many days.
You are inverting DC to AC then back to DC to keep a battery charged?
The battery charger will charge my motorcycle battery. For those saying just use a jump box. If it was an urgent situation sure. But it's not urgent and having a fully charged battery is the gold standard here. Besides.....when you run a bike with an undercharged battery.....it makes the electrical charging system on the bike work harder. I don't want that to happen...lol.... I want a fully charged battery from the moment I turn the key until I'm done riding. The power bank arrived today and I will use it tomorrow and report back. Thanks to all who responded! |
| All times are GMT -8. The time now is 08:37 PM. |
