TPMS Question.
With our cooler temps...I had a dash light on for low pressure on the front right tire on my Civic. Topped it off and the light disappeared.
Talking to a friend that has a year newer Civic....he said Honda moved away from the tire sensors a couple years ago and now they use the car's ABS brake system to monitor tire pressures. I've never heard of that. I'm glad that I don't have to change low battery sensors any more. Wondering how it can work? Do other brand cars do the same?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Never heard of that. I do always add air when the cold gets here. Lights on the dash drive me crazy.
Keep talking, Im gonna put you in the trunk. |
Detects difference in rotational speed/energy required to turn wheel
Well...sounds good, it's amazing to me that it can be done that way. I did notice that when the dash light came on, it specified which tire and what the pressure was (26 lb.) My 2010 Fit would only light up that I had a low tire..not which one or the pressure.
I think this is independent of whether your car gives you per tire info or just a warning that there's low pressure on on tire. I think/suspect the difference between per tire or one-of-the-tires warning systems is more about cost/feature. https://www.tirerack.com/upgrade-garage/different-types-of-tire-pressure-monitoring-systems Quote:
I remember getting the light on my 2010 Fit for TPMS system trouble. I brought the car in and they replaced the sensor in one tire because the battery was dead. A month later, the same thing but different tire. I asked them to do the other two also.
I should have just had them do all four at the first stop. I was told 8-10 years is the average life. Mine made it to 10 I'm glad that part won't happen with the Civic.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 11-24-2024 at 11:27 AM.. |
The Internet seems to think that the wife's 2018 Outback also has sensors. I suspect they may be getting ready to go out. They seem to work, we get numbers for all 4 wheels. But twice now the warning light started blinking and then stayed on which I believe is supposed to indicate a problem in the system. I suspect the battery is going bad in at least one sensor.
Funny thread, I am adjusting air pressures today for my daughter's Honda Civic, son's Santa Fe, sons fiancé's Corolla, wife's RX350, and my daily RX300. The RX350 light will also come on when the spare is low. The only vehicle in the group that is showing low pressures is the Civic, but I figure I've got everything out to perform the task, so may as well check them all.
I'm not sure how the tpms works in the vehicles I test at work, I do know that sometimes just the tpms light will be on when some sort of repair or recalibration has taken place and we either take the vehicle through the roll booth or drive the vehicle for a short stint on the track until the light goes out. Sent from my SM-S916U using Tapatalk
"A little nonsense now and then is relished by the wisest men." Wonka |
Kantry Member
As mentioned above, VW uses the ABS system to monitor for differences in rotational speed. Relatively simple and no remote sensors. The system seems to be able to detect a 5psi difference.
Best Les
Best Les My train of thought has been replaced by a bumper car. |
Navin Johnson
My 07 Cayman shows a little schematic with tire pressures... just cycle through the display options ..
![]() Also some of the better scanners can display the battery status of the sensors, mine is an Icarsoft. Also a lot of shops have a scanner you hold near the valve stem which gives you all the info... Whats interesting is the wheel temp is 73F ambient here is 51F now..I wonder if that is the temp of the air in the tire, or the physical wheel. ![]()
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 11-24-2024 at 12:45 PM.. |
Yep, I love it. And it seems to be on the money. I fill the tires and get the fronts to match and the rears to match and 98% of the time the display has them matching exactly. As they warm up, one may register the increase sooner than another, but they all eventually match. So I'm able to tell if one tire has a slow leak compared to the others. The system in my wife's outback is similar, but reacts more slowly.
Navin Johnson
Also it interesting that the dash display show FL 30psi, yet the scanner shows almost 32psi... not a rounding error, Though I'm not worried about it..
I love that Porsche shows the front one pixel narrower than the rears, and they show the diff
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 11-24-2024 at 01:47 PM.. |
Brew Master
Low battery sensors? Never had that happen. But the oldest vehicle with TPMS is my son's 2008 Rav.
Nick |
^^^ I've heard some say that the battery can be replaced on it's own...but it's much easier to just replace the whole sensor.
I think they were only $25 each for my Fit. If his are original...that's a long life for them.
You do not have permissi
Had a Prius with15lbs of air in one tire. No dash code..
The sidewall still 'looked' perfect because it was a Micheline Defender 5-ply sidewall. I've read they changed. IDK. Mighty tires. Also had to get new sensors replaced. The tire shop (discount) said they had problems with OEM reading the aftermarket signals.
Meanwhile other things are still happening. |
Fleabit peanut monkey
It's $250 at Costco if that's all you do. Amazon has four for $25 but you have to change them yourself and program to your car. I need to learn how to do that. I don't think it's that expensive once you get a little machine/scanner thingie( $10-$250)
1981 911SC Targa Last edited by Bob Kontak; 11-25-2024 at 05:38 AM.. |
^^^ It was at Walmart.
I think I had it in for tire rotation and they just added the sensor costs to the rotation fee. That's about all that I trust them to do there...but I've never had any problem with them.
My MK6 VW Golf uses the ABS system to detect a decrease in tire pressure.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Having the ABS system will make a difference to me on a decision of whether or not to swap some snows and rims on the front of my Civic for the winter.
With the tire sensors, either have to live with the dash light on for the winter, or swap the two sensors each season. If I buy two new sensors, the system has to be recalibrated twice each year.
With the VW, I am able to select "snow tires" within the multi-function display for the TPMS.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI Last edited by GothingNC; 11-25-2024 at 01:20 PM.. |
