Fell into a 2004 Honda Pilot that is extremely well maintained what should I know?
Thoughts from any Honda Experts appreciated
Sent from my iPhone using Tapatalk Pro |
1 owner. Extremely well maintained
Keep it forever
Sorry 04 EXL 120k miles
Did that year have the bad paint issues?
No paint issues on this one
Timing belt /tensioner, use only OE Honda, or AISIN parts. Change the transmission fluid every 3-4 oil changes, its cheap and easy, just a drain and fill . Only OE Honda Fluid .
Ive replaced a few halfshafts, starters, alternators, ac compressors and a few other basic things on higher milage ones , but for the most part, simple maintenance, without rust, easy 250k. There is a valve adjustment interval also . I've had to cure a few missfires at super high mileage by a simple valve adjust, when other shops measured compression and condemmend the motor as having a bad cylinder/burnt valve . Super pedestrian , and about as exciting to drive as a lawn cart, but solid, practical vehicles . Nice score . |
Thanks I figured heck for what paid for it in cash that’s only a couple weeks worth of a car rental so had to buy it. Nice to have a few back up drivers ect.
If it develops a miss adjust the valves. Keep the trans fluid changed, ignore the book and change it with castrol synthetic or OE Honda fluid annually- it's absurdly easy to do. Honda transaxles from that era are fragile. Keep an eye on the belt tensioner as well.
rj[ |
I have a 2011 Odyssey with 153k on it that I bought new and it has not had even one problem.
| All times are GMT -8. The time now is 07:22 AM. |
