Welding to an electric motor casing
The spot welds on the mounting bracket to my tumbler motor all failed. Easy to weld it back on but should I pull the armature out of the motor first? It's a basic single phase 3/4 hp motor.
https://cmtopline.com/products/mr-deburr-db300-3-4-horsepower-single-phase-motor?variant=45313724645614&gad_source=1&gclid=CjwKCAiAhP67BhAVEiwA2E_9g5fjP0K-tu4ZlCkebJIgS2STdH0o38EYlKZaeCxyUKAmYKcJYuL2jhoC2U MQAvD_BwE
Tru6 Restoration & Design |
Kantry Member
Knowing how easily the thin insulation on the windings can be compromised, I would strip it down to the casing before welding.
Best Les
Best Les My train of thought has been replaced by a bumper car. |
You don’t have to pull the armature.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Control Group
I know you are listening to Les
She was the kindest person I ever met |
Heat is the enemy of electric motor windings so I would strip it down.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Counterclockwise?
Cover should come off pretty easy without a major teardown?
But isn't the mounting bracket part of the motor itself?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
As I should have known, there's a bearing on both ends of the spindle and removing the pulley end one would have destroyed that one. So with both ends loose/off, I drilled new holes in the mount and sanded a clean finish on the case and welded away. Back together, works perfectly. That said, I measured the bearings and have ordered new ones so I can replace them at some point. Thanks for the replies.
Tthe mount/bracket/cradle is spot welded to the case.
You do not have permissi
What about glue + mechanical type fastener instead?
Anything nearby to grip onto? (edit-too late)
Meanwhile other things are still happening. |
It's been working all day, and the tumbler has new vigor, so it must have been soaking up some of the oscillation for quite some time giving up the ghost today.
