Showing Off My Fence I Built & Seeking Recommendations on Sealers
I built a new side fence last week which enlarges my small back yard by 5' and is a little taller than the old crumbling fence. I'm just showing off my handywork here but also asking for recommendations for a good sealer. I've used Penofin in the past, but it doesn't seem to hold up as well as I would like.
This is a "good neighbor" fence as it looks the exact same on both sides with the fence pickets overlapping 1.5" over one another. I'll be adding railroad ties along the sidewalk to create a short retaining planter and then planting shrubs. I will also remove the old driveway on the left side and replace with dirt - this hasn't been in use for about 50 years. After this, I will build a fence on the other side of the yard and then the back side so it will all be the same. Setting Posts: http://forums.pelicanparts.com/uploa...1741028213.jpg Building a Frame: http://forums.pelicanparts.com/uploa...1741028245.jpg Finished: http://forums.pelicanparts.com/uploa...1741028275.jpg |
Looks great!
Cedar? If you seal it once, you'll be back every couple of years to re-seal. I left mine un-sealed, but some people don't like the grey look. I would seal it before assembly. Why didn't you go up against the sidewalk like next door? |
Looks great. I use Messmers UV plus on exterior wood. Check for procedure for new wood.
That is NICE. I got nothing on what sealer...
What Marv says.
TWP is good, so is CWF (made by Flood). Run, don't walk, from Thompsons.
Thanks for the recommendations. I looked up the products and read the instructions and it looks like I don't have to do anything for a few months - need to let the wood age a bit. This gives me time to get the rest of the fences built.
This place is slipping . No mention of baby poo yellow fence paint .
Fence looks great by the way !! |
Gorgeous fence, Vern! Excellent craftsmanship, from what I can see, too!
Good idea to build it outside the old one. I may steal that idea as one of mine is in poor condition right now. Can't help on your question but I see some replies which hopefully will help. Thanks for sharing! |
PS - Is that a Kumquat tree? :)
Also, regarding the shrub planting on the outside, whenever you get to it, Indian Hawthorn is a very durable and low maintenance low in height shrub. They aren't known for their flowers but they do bloom in the spring.
Rhaphiolepsis indica (botanical name) or just Indian Hawthorn - in a 3 gallon size is what I usually use. Try to buy from a wholesale nursery. Retail pricing on plants is crazy right now! There are of course other plant choices but if you want durability and don't want something that grows too high, this would be a good choice. |
"Showing Off" would not be the best phrase to use, maybe "Bespoke Invitation To Private Viewing."
The driveway section doesn't look like it moves. Sliding gate later on? That would be a nice feature to keep. For a future selling point. Or when uncle frank's RV transmission needs a swap. It's easier to have than apply for city permit. Or is the plan to break up the concrete and permanently naturalize? |
Check out Green Island Ficus..... |
| All times are GMT -8. The time now is 05:49 PM. |
