-   -   Size of fence posts? (http://forums.pelicanparts.com/off-topic-discussions/1177352-size-fence-posts.html)
masraum 05-05-2025 12:56 PM
Originally Posted by David (Post 12459380)
4" is plenty but I go 7' between posts rather than 8'. Adds to cost but helps when a hurricane shows up. We also run 3 horizontal 2x4's rather than 2 and a 1x6 treated rot board at the bottom.
The first time I saw that rot board at the bottom, I thought it was genius!
KFC911 05-05-2025 01:04 PM
I'll prolly do similar but might use 4x6s ... not long runs tho...
Just because it's stoopid ;)
stevej37 05-05-2025 01:33 PM
Back side of my property wood fence. Strong wind a couple years ago snapped off three of the twelve foot sections. 4X4 treated posts.
http://forums.pelicanparts.com/uploa...1746477158.jpg
KFC911 05-05-2025 01:40 PM
^^^ I recall some jeanyus suggested shorter spans rather than dig out old posts :D.
rockfan4 05-05-2025 01:49 PM
Metal posts - he uses steel for the fence, but you could use wood pickets.
<iframe width="359" height="638" src="https://www.youtube.com/embed/Tv3o3WE2wX0" title="Building A No Dig Fence To Last 100 Years" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
masraum 05-05-2025 01:58 PM
Best bet is pieces of old railroad rail cut to 10' lengths, set 4' into the ground with 2-3 bags of cement, and then railroad ties used for the rest!
rfuerst911sc 05-05-2025 02:02 PM
I bought one 6x6x8' pressure treated post at HD today for 35 bucks . For 100 ' of fence that's going to add up quick ! I would go 4x6 or 4x4 .
stevej37 05-05-2025 02:22 PM
Yes I remember that. Good advice.
I did one better though I burned the broken sections and left it open.:D
Tidybuoy 05-05-2025 04:14 PM
Another suggestion is to get your 2x4's at a lumber yard that offers rough cut boards vs the stuff you get at Home Depot. They are noticeably thicker and look better. I found that the cost was about the same as smooth cut at Home Depot.
gregpark 05-05-2025 04:52 PM
http://forums.pelicanparts.com/uploa...1746489007.jpg
4x4 PT with no wood to concrete or dirt contact and it'll last longer than the old guy neighbor
cabmandone 05-05-2025 04:55 PM
Originally Posted by 911 Rod (Post 12459297)
The type of fence where the boards stagger from one side to the other.
He and my son are adamant that it will be a better fence with 6" posts.
Maybe the fence guy has extra 6" ones and wants to get rid of them.
The quote is for $6500.
I guess I should just stay out of it and mind my own business
Are you talking basket weave fence, with 6" posts for $6500? :eek::eek: I'll hire them next if so.
Cajundaddy 05-05-2025 05:13 PM
In SoCal we only ever used 4x4 and they only failed due to rot, never broken healthy wood. If they really want 6" and the quote is reasonable, just have it done. No reason to fuss about it. Maybe the local fence guy knows something we don't. Soil and weather conditions vary a lot from state to state and I appreciate local knowledge.
3rd_gear_Ted 05-05-2025 05:43 PM
I have a 150" fence with RR ties for posts @ my Lazy H Ranch.
Got the RR ties for free off an abandoned spur line all tore up.
juanbenae 05-05-2025 06:04 PM
Or simply offset the 1st section to 6' or 10' if the existing post are on 8' centers.
Alot of fences up here use old steel from wells for posts. My neighbor had one built with old 2" galvanized retired well pipe last year, rust and all. Infact when my well pump signed off last August the guy who I used to replace the pump and pipe turned me onto a dude who would come collect the 1" pipe. He made hog fence panels out of it and was thrilled to take my 700' away. Only I was more thrilled to not have to cut and take it to the metal recycler.
juanbenae 05-05-2025 06:22 PM
The other thing is pressure treated lumber is like most lumber these days and is not dense old growth and will rot pretty dam fast. Today's redwood is the same, and not much better. See the 1x6 slats that are as much white as they are red.
The PT being usually a doug-fir is a joke 4x or 6x. Too much soft new growth product that is very cellulose and even if using PT it absorbs moisture quickly. If I were building a fence, I'd look to get even cyclone fence post driven w/o concrete and then go to the wood. The companies that do cyclone have pneumatic drivers, imagine an air powered T-post driver...
gregpark 05-05-2025 06:46 PM
Todays PT does not rot easily as long as there's no earth to wood contact. It's not as good as it was back in the day when it was super dark green. They advertized to last 40 years buried in a tropical jungle. It was deemed too carcinogenic and I'm sure they were right. Cheap redwood from a big box store is not worth using in my opinion. Cut from 8 year old farmed trees and not much better outdoors than fir or pine. The "white" grain you refer to is called sap wood and rots faster than interior soft woods. You can still get old growth, real deal redwood but you'll pay dearly for it. For framing outdoors I go with PT and dont let it touch the ground or bury it in concrete
gregpark 05-05-2025 07:13 PM
http://forums.pelicanparts.com/uploa...1746497114.jpg
A pic of one of the sono tube footings I did for a deck at my house 10 years ago. The home cheapo PT is still solid as when I bought it. The second pic is a corner of the railing I did with heartbeat, old growth, straight grain redwood that cost me a small fortune. The railing shows but I don't care about the ugly posts
juanbenae 05-05-2025 08:21 PM
The S4S redwood for decks & rails is much older growth to be sure, but if redwood has white, light streaks in it is less dense and more likely to take on moisture. Your post is painted and directly loaded so it out of the moist soil. A fence post in concrete might as well be direct buried in dirt because the moisture infiltrates. Go ahead and slope the post concrete so water does not collect and drain into it, you can still push it over in like 4 years.
gregpark 05-05-2025 09:03 PM
I set the Simpson post mount's floor a half inch above the concrete. The pressure treated uncut end of the post sits on the galvanized platform of the mount and is never sitting in ponding water. I expect posts set like this to last longer than me. I've done fence posts (with cheap PT 4x4) the same way and they're pretty much a forever post. I poke a few 2' junk steel rods or heavy wire down into the wet concrete too
juanbenae 05-05-2025 09:15 PM
Dude, you are comparing apples and oranges. A weighted, structural post like you show is not like a fence post buried in the ground... The expectations of those differing conditions are huge.
A weighted post does not act like a fence post with its lateral, side to side need. I do respect your preservation painting.
Apples n oranges.
