How do they make it so cheap? They can’t and they aren’t. Massive Chinese government subsidies are killing manufacturing everywhere else.
They are playing the long game here and sadly they are winning. The tariffs are the only way to keep them honest. |
There's still a labor cost issue that no amount of "public investment" will overcome. Literally every country that is beating us in manufacturing is doing so with low wages, no benefits and virtually no environmental protections in place. |
When I was was engineering manager at a API licensed facility, we could not buy the material to make an API 6A flange for what your could buy an identical monogrammed API 6A flange made in China.
Materials were equal, the design was the same (standard parts), everything equal. It costs the same to run a CNC machine in North America as it does in China. They were losing money on their flanges. Why? |
I’m not sure if this has been touched upon but when you buy no name you’re not paying for bricks n mortar dealer stores or their overhead.
A HS friend of mine somehow ended up in Vietnam and is working in a furniture factory. People in there make a living on salary of $300/month. Different economy. |
My biggest concern is parts. My friend and I discussed the issue of parts and decided that if we order a container load, we'll order a second container with attachments and parts. I think advertising that we stock parts will be a big help if we decide to go forward with this. |
Well! Not gonna get to use it. My friend had it advertised and had a few buyers pop up so I told him to sell it. But now we're serious about getting our hands on a container of them.
I got to operate one. It's definitely not in the same class as Bobcat, Kubota, Vermeer, Toro.
The steering joystick controls the machine smoothly but the lift/tilt function is problematic from a power distribution standpoint. When traveling with the engine at full rpm, if you try to feather the boom up or down slowly, it causes the engine to bog down heavily. If bring the boom joystick to full up or full down quickly it doesn't bog the engine down but any attempt to feather control causes the engine to bog. When lifting the boom and tilting or curling the bucket, it will only do one function or the other. So If I want to adjust the bucket angle while lifting, it won't do it. The machine seems well built but the finish isn't close to the same as the big boys nor should anyone expect it to be for the price point. My concern is that this is definitely a higher end homeowner unit and not really a machine that a small to medium size landscaping business would consider due to the functional issues. I'm probably still going to buy one to see how things go but I was disappointed in it after operating it. |
I ended up ordering what appears to be a more "professional grade" machine from a different manufacturer. I also bought one of the machines I operated at post #30 but this one had a Perkins engine. It was like the Perkins machine had 10 more HP and way more torque than the Kubota machine. I figure if I'm gonna sell against it, I have to know it.
One thing that has caught my eye, Chinese manufacturers seem to use steel the way we use lumber in crating. The machine I bought has a welded steel frame as crating with wood screwed to the outside. I've seen attachments crated the same way. It's like their steel is cheaper to use than wood. |
No question about that. I did a few projects with "steel " I got for free from a friend who used to import ATVs from China. All the crates were welded and bolted frames. No wood at all.
Steel doesn’t have bugs in it so it can be shipped to any country.
Many countries require pressure treated wood or osb for crates. Steel would have no such requirements. |
Thought I'd post a pic of the machine I've been using and the one that caused me to start the thread. This is the Derette V1000. I've put almost 10 hours on it since bought it. It's not bad but it's not something the professional user would want. It lacks a multi function valve, so when you're operating a powered attachment like a brush cutter or harley rake, it won't lift the boom. Some things from post 31 that I'll correct. The bog down problem is more pronounced with the Kubota engine. The machine with a Perkins engine doesn't seem to have that problem. The machine will lift and tilt at the same time, it's just that the joystick is in a different position than I'm accustomed to with other machines. Typically you'd pull all the way back and then to the left or right to raise the boom and dump or curl the bucket. On this machine you pull back just a little and then to left or right.
I'll post a pic of the more "professional grade" machine once it gets here. It's supposed to be in Chicago by the 12th and then delivered to me. http://forums.pelicanparts.com/uploa...1759919860.jpg |
| All times are GMT -8. The time now is 12:07 AM. |
