lubricant for small electric fan in small appliance that is heat tolerant
We've got a Breville convection toaster oven. The fan has started to make some noise. Based on online searches, it seems that parts are NLA (and nearly impossible to change), but most folks report good results from spraying some lube on the shaft at the motor. And it's apparently very difficult to get the cover off of the oven because of the placement of a couple of screws. Most folks only get as far as being able to get the side pulled back by an inch or two, so they have to use a spray that's got a hose (like WD-40). I've seen things mentioned like lubes with teflon and silicone lubes.
I've heard lots of stuff mentioned. I'd just like to use whatever would be best (long lasting, hard to dispense under the circumstances, able to deal with high heat). The lube is outside of the cooking environment, but there's no insulation, so it'll be subject to heat. The back of the motor has a fan blade to keep it cool.
Here's a shot from the one guy that actually completely removed the cover.
This is the usual view
Old 06-18-2025, 11:37 AM
Shaun @ Tru6's Avatar
Silicone is heat resistant.
Tru6 Restoration & Design
Old 06-18-2025, 11:40 AM
Good to know.
I saw the temp range at the bottom of the description of the WD-40 silicone lube and thought, "perfect," but then I saw the bit about creating a film after it dries which doesn't sound ideal. I'll check some others.
WD-40 Specialist® Silicone Lubricant safely lubricates, resists water and protects metal and non-metal surfaces such as rubber, plastic and vinyl. Once dried, this formula leaves a clear, non-staining film that doesn't stick or make a mess, so it won't attract dirt. This silicone lubricant spray is great for use on cables, pulleys, guide rails, valves, linkages, hinges, locks and more. Effective in-use temperatures ranging from -100° F to 500° F.
Old 06-18-2025, 11:49 AM
908/930's Avatar
Can you bend a piece of wire and get it to the motor shaft? If so my usual would just be synthetic engine oil, 5 or 10 w whatever. Just use the wire to transfer a drop of oil and let gravity flow it into the bearing. Krytox grease would also do a great job but most people don't have a tube sitting around.
Old 06-18-2025, 01:23 PM
Originally Posted by aschen View Post
Only thing to lubricate is the bearings right? THey are probably oilite bushings and not ball bearings right?
A tiny drop of oil on each bearing should be fine, but I wonder if the fan is causing somethng else to vibrate.
https://www.amazon.com/Synthetic-Lubricating-Controlled-Vehicles-Evaporate/dp/B00CVUR8S4
Yes, almost certainly bushings and need a bit of oil, but nearly impossible to easily get to the shaft. I'm not actually expecting the oil to work, but we'll see. Several folks online have supposedly had success.
Genius, letting the oil run down the wire. I think that's how some ninjas were supposed to have administered poison into the gaping mouth of sleeping targets.
Old 06-18-2025, 01:51 PM
908/930's Avatar
You should only need 1/2 of a drop of oil on the end of the wire, the small bushing should not need much.
Old 06-18-2025, 01:59 PM
MBAtarga's Avatar
It was attempted in a James Bond movie - IIRC, it got the girl instead of him.
Sewing machine oiler off Amazon:
https://www.amazon.com/ZOOM-SPOUT-OILER-MACHINE-U-S/dp/B077KDT2RZ
Mark
'83 SC Targa - since 5/5/2001
Old 06-18-2025, 08:03 PM
Ah, right, the one that actually had the secret base inside the volcano!
Old 06-18-2025, 08:05 PM
I agree - My go-to for this would be a drop of 5w20 synthetic (because I have it handy for the truck).
I've had trouble with Krytox drying out on motor bearings and then not being quite slick enough. The PTFE paste just flings out of the contact places and then doesn't really provide lube.
Old 06-18-2025, 08:44 PM
Cajundaddy's Avatar
Food grade silicone would be my choice. Also potentially a non-stick spray like Pam could work and will not poison you. I would avoid motor oil or PTFE as when it does reach flash point the off gas is toxic.
Here is a complete how-to by some unknown dude.
https://greenwaykitchen.com/how-to-lubricate-convection-oven-fan-2/#google_vignette
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 06-18-2025, 09:20 PM
pwd72s's Avatar
Super Lube brand makes a bunch of food safe lubricants.
https://www.super-lube.com/
Old 06-18-2025, 09:33 PM
wdfifteen's Avatar
Good to know.
The film is the lubricant. But this is not the best stuff for bearings. My approach would be, “I can’t use it as it is, so if I eff it up getting this cover off I haven’t lost anything,” and I’d get the cover off. I’ve taken things like this apart a lot, usually break some fasteners and have to get creative about re-attaching the cover, and almost always have parts left over, but I make them function. Ten weight oil like good old 3-In-1 should work fine. You don’t need to worry about “food grade” on the fan bearings. That doesn’t look like the fan in the food cavity, it looks like it’s there to cool the electronics.
Old 06-19-2025, 03:11 AM
Cool, I can manage that.
Good to know and definitely a consideration, thanks!
Good to know, but even more importantly, WELCOME BACK! I saw your post about a week ago, I think, saying that you were back and doing better, but this is the first post that I've seen other than that. It's GREAT to see you active on the board fella. I really hope that you're doing well (or at least much better and still improving).
I'm going to setup a gofundme to get you one of these so none of us have to go through this emotional rollercoaster again.
So you're saying that it's not drying to a dry film, possibly some sort of thinner that makes it easier to spray, and then it dries to a wet film of lube?
Yeah, there was a guy. The main issue is that there are a couple of screws that require something like 18" long small sized screwdrivers to remove.
The fan in the video is not the main fan. The motor has shaft sticking out both sides. One end has a fan mounted inside the cooking compartment to move the air around in the oven. The other side, as you say, has a small blade applied to keep the motor and stuff around it cool.
Old 06-19-2025, 09:10 AM
Counterclockwise?
Graphite dry lubricant.
WD-40 is not a lubricant.
Rod
1986 Carrera
2001 996TT
Old 06-19-2025, 09:18 AM
Nice suggestion about the graphite dry lube. I'm not sure if there's space to get the dry lube to the bearings of the motor though
Yes, regular WD-40 isn't a lubricant. The WD-40 that I posted above isn't regular WD-40. It is a lubricant - "WD-40 Specialist® Silicone Lubricant"
These days, WD-40 is essentially a brand that covers many products, including the original which is a drying agent, rust inhibitors, lubricants, etc...
Old 06-19-2025, 10:22 AM
This is my go to when things start to squeak or make noises they shouldn't.
Scott
'78 SC mit Sportomatic - Sold
Old 06-19-2025, 11:48 AM
