Long life Detroit engine?
My nominee..the old slant 6. Still being used to power unusual street machines today. Guess I'll always be a fan...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Most of the Big 3 straight 6s were reliable.
Later Chrysler 318s were pretty solid too. |
Make Bruins Great Again
Plymouth/Dodge 318 cid - not a torque monster but a solid motor that you couldn't kill.
I had one in a '72 Satellite Sebring and it was used and abused but never missed a beat.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
We had a slant 6 in a short bed 4x4 pickup... Holes in the floor, bed sides flapping in the wind, but plowed snow like a champ.
Kantry Member
Small block Chevy. The only bad ones I know of were in the late '70s. They has oiling problems on the cam shafts.
Ford 302 was all but indestructible. A BIL drove an old van from Toronto to Annapolis Royal and never thought to check the oil. 5 quarts brought it back to full.
Best Les My train of thought has been replaced by a bumper car. |
Control Group
Ford 300 inline 6
the end
She was the kindest person I ever met |
Fleabit peanut monkey
From WIKI - Pretty good run. Just a couple years short of the air cooled 911 engine but millions were produced.
![]() https://en.wikipedia.org/wiki/Ford_straight-six_engine
1981 911SC Targa Last edited by Bob Kontak; 07-31-2025 at 04:44 PM.. |
GM/Pontiac 2.5L Iron Duke, Buick 3.8L, Chevy 4.3L...
Retired Member
5.3 iron block in my last 06 Tahoe. No afm, only had to replace spark plugs and a couple of coils over 11 years of ownership. Vehicle had over 350,00- km’s when I traded it in.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Maybe not the use case you intended, but I'll leave this right here:
https://en.wikipedia.org/wiki/Chrysler_A57_multibank |
Team California
This is what came to mind when I saw this thread title. Hundreds of thousands of miles with no apparent wear. Really pretty remarkable. Cummins and 7.3 Power Stroke diesels as well but diesels are very maintenance dependent. Those Chevy Vortex and LS motors don't seem to need much, just reasonably clean oil and a functional cooling system.
Denis |
Never owned a 300 6 but I sure wanted one. 7.3 now. Went slightly over the speed limit in a full size truck recently. Pulls well.
Air Medal or two
Anything with Fiat and Chrysler attached to it.
The 5.9 Cummins with VP 44 had plastic piston cooling jets. These would sometimes jump out of the upper main saddle and burn that bearing up, scoring the ascribed cylinder. The engines now with belt-driven oil pumps dwn inside the engines, seem to be creating a few disasters. (ford and maybe some others)
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Brew Master
I'm with Tobra on this one. Those things were about as bulletproof as any engine could be. They put those things in one ton work vehicles!
Someone mentioned the Chevy 4.3... solid engine too but I don't think it reached the level of reliability of the Ford inline 6. For modern I'd go with a NA 3.5L from Ford. Those things lasted. Why the hell Ford chose to go turbo "ecoboost" is beyond me. Toytota is still cranking out a NA 3.5 that is rock solid.
Nick Last edited by cabmandone; 08-01-2025 at 04:27 AM.. |
Control Group
7 main bearings on a six cylinder motor is the key, IMHO
My understanding is that the straight 6s were pretty bullet proof, Chrysler 225, Chevy 250, and Ford 300. I think the SBC would have to be up there too, and clearly based on this thread the 318 (what about the 340 and 360), and then Ford 289/302. And I wonder about the 70s SBC issue that was mentioned, was that actually the motors or a change in the oil formulations. I saw a thing the other day by several motor/oil guys that said that there was a problem at one point with cam lobes that was due to motor oil formulation.
Brew Master
I think the 318 needs a clarification. A 318 with lean burn wasn't a long life engine. Take off the lean burn system and they were great. Funny thing is, they ran like a scalded dog.
Nick |
Slippery Slope Victim
I worked on a ton of 6 cylinder cars back in the early 70's. They were all pretty bulletproof if you did regular maintenance on them. We had a Dodge van with a 225. It destroyed itself when the nylon gear on the distributor disentegrated. The first engine I ever took apart was a Ford six from a 66 Mustang. What a mess I made in the yard when I failed to drain the oil when I started to dismantle it, I was 14. Dad was not happy.
MikeČ 1985 M491 |
Edministrator
Agree. Plus a naturally smoother balance to it. One head, less parts.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Currently have a Hyundai with 108k and going strong. Also have two other Hyundais that have 60-75k.
