Lugs nut locks
A friend of mine has wheels with a lock nut that he has no key. How do you get one off?
Thanks. |
When I bought my Land Cruiser, I got a year or so out of the tires.
I have been going to the same tire place for decades, and they asked for the lock nut thingy…the one in the car wasn’t it. I drove to the Toyota dealership with a picture of the lock nut key I needed. They would only sell me one, even though they had one I could have borrowed if they were human. I bought four lugs and Big Ed drilled out the lock lugs and replaced them. I live in a rural area so moving on from the locks wasn’t an issue…seems like an odd failure mod if on the road.
1996 FJ80. |
Search for 1/2" dive Bolt extractor set. Something might pop up. (edit) Then think about it...maybe wheel thieves also know of these sets?
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
That is really the issue. There are some folks, if they want your tires, they will get yout tires.
1996 FJ80. |
It depends upon the nuts, of course. Years ago, I bought a Ford Ranger that had lock lugs but no key. I knew a kid that had been a hoodlum when he was younger. He gave me the solution that worked for me.
I bought a Craftsman 6pt ½ drive socket that just barely didn't fit on the lock lug (in my case, he even gave me the size, I think it was 13/16, but I can't remember for sure). You then hammer the socket onto the lug nut and use a breaker bar to take it off. You're probably going to need 4 sockets because once you get the socket on the nut, you're not going to get it off.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Fleabit peanut monkey
Reminds me of the story where the guy chained his 911 between two trees - long ways - and when he returned from a trip the car had been spun 180 degrees and re-chained and a note was left that said when we want it we'll come and get it.
1981 911SC Targa |
Air Medal or two
Can we get a pic of the situation?
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
P-car ones are simply defeated with a slightly larger socket and mini sledge over the lug nut.
That’s how i snagged my last set of big blacks from the junk yard.
dolor et pavor Copyright |
Hundreds of videos on each style. Me, I'd probably quickly weld a short length of pipe on each one from the inside with a cheap arc welder, use a pipe wrench if the wheel isn't too deep, and throw the things away. |
Thanks everyone, I will pass on the word
I also tried to get the socket off of the lug once it was pounded on and wasn't able to. In my case the locking lug was round and somewhat spherical. It does, I'm sure depend upon the locking lug nut style/design. Last edited by masraum; 08-02-2025 at 05:42 PM.. |
Snark and Soda
A lot of times a dealer will have a master set of all keys if the nut is a factory accessory. They could remove them and sell you new nuts.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
They make a special socket with an internal tapered left hand thread for these situations. It bites into the OD of the locking lug. Available at the usual auto parts stores.
The plot thicken,. Aftermarket lugs.
I tell him either go to a tire place or get an extractor and pound it on. Then put breaker bar on it and have at it. Thanks again everyone. |
Southern Class & Sass
Use this.
Dixie Bradenton, FL 2013 Camaro ZL1 |
my memory is foggy, but I seem to remember hammering on a 15/16 socket and wedging it on there in an emergency.
but yea..I have the extractors. used them exactly once, now they just bounce around tool drawer to tool drawer. no more locking lugs for me.
poof! gone |
Something like the kit that Dixie posted is probably an even better bet. I've got some of those, but for bolts, not the necessary sizes for lug nuts.
Snark and Soda
Just don't put a lock on the lug nut removal kit.
When it happen to me i welded a nut to it worked great
I've got a soldering gun and a tube of JB weld. I'm not sure either would work in this case.
