-   -   How long can brake fluid sit in the can? (http://forums.pelicanparts.com/off-topic-discussions/1182551-how-long-can-brake-fluid-sit-can.html)
Gogar 08-18-2025 06:00 PM
Hello!
I have some Pentosin DOT 4 that's been in the can on the shelf for let's say 6 or 7 years.
The can was mostly full and I'm in dry Colorado.
It "seems" fine and looks way better than what I'm replacing lol. Looks like very weak iced tea.
What say you? Thanks
Shaun @ Tru6 08-18-2025 06:19 PM
There will be two schools of thought on this. Any brake fluid opened, sat in garage, 1 year and it goes into the trash. Or it’ll be fine in your commuter car, just use it.
Arizona_928 08-18-2025 06:50 PM
Put it into a desiccator next time. For even race applications, a sealed lid on an open container will contain negligible amounts of water. A deuterated solvent used for nmr, not so much. lol
onewhippedpuppy 08-18-2025 06:54 PM
Standard wisdom is that once you’ve opened it to the air, two years. No different can vs brake system.
Baz 08-18-2025 07:08 PM
BF's downfall is it's propensity to absorb water through moisture in the air. When this happens it turns the BF into a mushy nasty looking material. If your fluid still looks clear you're probably OK.
That said - considering BF is still fairly reasonable in cost - not sure I would use it in anything you really care about.
Gogar 08-18-2025 08:06 PM
Thank you
It's bike stuff so I'll probably buy a new can and start over, should take 10 minutes lol.
The reservoir looked pretty nasty but is ok now after some TLC.
speeder 08-18-2025 09:05 PM
Instead of guessing whether brake fluid is contaminated with moisture or not, just invest in a cheap electronic tester from your favorite big box store on the internet. Then you don’t need to throw away good fluid or depend on some stranger’s opinion. As a bonus, you can also use it on the fluid that’s in your vehicle to tell whether you need to change it!
speeder 08-18-2025 09:09 PM
And while fluid that looks nasty is obviously contaminated, it’s not true at all that clear looking fluid is ok or that you can tell by appearance. I do this almost every day.
Gogar 08-18-2025 09:31 PM
Thanks Denis! I do have the tester and it didn't mind my can of fluid 0% i just had a consummate thirst for all the knowledge. :)
KFC911 08-19-2025 01:41 AM
Thank You ... I need one now ;)!
flatbutt 08-19-2025 07:59 AM
This has been a constant question for me as an MC owner. I use so little fluid when I bleed the system that easily 70% of the bottle contents end up sitting on the shelf.
speeder 08-19-2025 08:18 AM
I have a couple of unopened cans of ATE "Super Blue" from the early 2000s sitting around, I'll accept bets that they test zero moisture when I open them some day. I'll video the whole thing. :)
There are so many wive's tales about the fluids and lubricants we have in our machinery. My favorite, (or least favorite), is that oil goes bad in the crankcase when a car is parked for a long time. Or that seals dry out in the engine from sitting. All parroted on the internet by people who have never revived a long sleeping engine or disassembled an engine, etc. It is true that gasoline goes bad in an ugly way from long time sitting.
Heat and stress kills seals, period. Not bathing in oil for years. There is a film of oil on even the top end of an engine that has sat for years. The front pulley seal on my F-250 Power Stroke just started leaking, that is a vehicle that does road trips pulling a trailer. I'll change it, no big deal. Seals are important, don't get me wrong. So is dry brake fluid but getting a tester was a game changer for me. No more guessing. :cool:
gacook 08-19-2025 09:38 AM
I'm the other school of thought. Open brake fluid can, use what's needed, throw rest away. Zero open shelf time.
Tobra 08-19-2025 11:13 AM
I am with Guy.
How much is a bottle of brake fluid, pretty cheap
dad911 08-19-2025 11:54 AM
I have a few cans also. Thanks for the link to the tester, I didn't know such a thing existed.
Tobra 08-19-2025 12:05 PM
In an unopened undamaged container, it would last practically indefinitely
onewhippedpuppy 08-19-2025 12:10 PM
As a counterpoint, there are probably millions of old cars on the road with working brakes that still have original fluid. So we are probably overthinking it.:)
A930Rocket 08-19-2025 03:12 PM
^^^ My 2001 F150 had the original brake fluid when I traded it for my 2014 F150. 🤯 But, I changed the brake fluid in my track car every event. So probably 6 - 8 times a year.
I’ve changed the brake fluid in my 2014 F150 several times
Bill Verburg 08-19-2025 04:35 PM
Why guess, an e-brake fluid hygrometer costs <$25 and will tell you whether the fluid is still good or not.
Gogar 08-19-2025 04:47 PM
I agree! Why read the thread? Just go to the bottom and fire away.
:p
