-   -   Please explain this weld fillet gage to me (http://forums.pelicanparts.com/off-topic-discussions/1184266-please-explain-weld-fillet-gage-me.html)
masraum 09-28-2025 07:17 AM
I'm curious why some of the things are 2 small semi-circles and some are one single semi-circle.
For instance in this photo, you see one end has what appears to be a huge radius and says '7/8"' while the opposite end of the same leaf has 2 partial curves that say '1"'
http://forums.pelicanparts.com/uploa...1759068820.jpg
another view
And the back so you can see that some are one 90º arc while others are 2 smaller (60º?) arcs.
I would expect all of the measurements to be the same, either 1 90º arc or 2 smaller arcs instead of a mix and match.
TimT 09-28-2025 07:40 AM
It can be used to measure concave or convex filet weld profiles.. Its really a comparator.. you place it flat on the horizontal and vertical surfaces, and check weld leg length, and throat..
<iframe width="560" height="315" src="https://www.youtube.com/embed/txQkfE756HU?si=aciPbythNz1v4vvI" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
masraum 09-28-2025 09:22 AM
Right, but what I don't understand is this. THese are the two ends of the same leaf. Do they measure 2 different things?
http://forums.pelicanparts.com/uploa...1759076529.jpg
TimT 09-28-2025 09:39 AM
Yes one end measures the leg, the other the throat...leaves room for interpolation.. The video is a pretty good demonstration of their use... The last pic you attached you can check throat on a 1" filet, and leg on a 7/8" filet.
These gauges are only suitable for filet welds...other gauges are available are used for butt welds etc..
With this you can check leg and throat of 5/8 or 1/4" filets
http://forums.pelicanparts.com/uploa...1759077325.jpg
Nomenclature
https://weldguru.com/wp-content/uplo...illet-weld.jpg
TimT 09-28-2025 09:45 AM
Also I think when they were developing the tool, the amount of real estate was fixed so
some of the larger sizes are mixed and matched..
masraum 09-28-2025 09:49 AM
Thanks tons for the great explanation and the video, Tim. I hadn't watched the video yet, and you were right, that and your subsequent posts cleared it right up!
TimT 09-28-2025 09:50 AM
II retired 4 years ago, and stashed all my equipment and odd and ends tools away in a closet...
I just pulled out my go-bag with weld test equip..
Filet gauge and multi gauge...I probably got my filet gauge around 1985, the other in the '90s
http://forums.pelicanparts.com/uploa...1759078195.jpg
TimT 09-28-2025 09:52 AM
The multi gauge allows measurements of all types of weld, and give direct measurements, instead of allowing interpolation
http://forums.pelicanparts.com/uploa...1759078304.jpg
masraum 09-28-2025 10:31 AM
Very cool! Thanks for sharing.
