Glue "raw" plywood to painted wood possible with titebond?
I've got some wood that was painted white (purchased pre-painted from somewhere, not sure where, like door frames that you can get at HD). I built some frames out of the wood, and want to attache the frames to 1/4" ply.
Will titebond work or does that really require wood-to-wood contact? If so, could I use something like liquid nails or construction adhesive instead?
Specifically, this titebond
Old 10-20-2025, 05:04 PM
id10t's Avatar
Think you'd want an epoxy like Gorilla Glue
Old 10-20-2025, 06:03 PM
Yeah, that's what I'm thinking too. I'll have to pick up the right glue tomorrow.
Old 10-20-2025, 06:12 PM
Model Citizen
herr_oberst's Avatar
If it was me, I'd give the pre-prime a few strokes with the edge of a new hacksaw blade, using it like a scraper to give the surface some tooth for the glue to lock into. Glue it, clamp it. Titebond is pretty good stuff.
I'd also test a piece, first.
Old 10-20-2025, 06:16 PM
You do not have permissi
john70t's Avatar
It's as strong as the paint bond on both sides I'd guess.
Some mechanical bonds such as screws or trim nails would help. Or chisel off a 1/16 in areas.
Old 10-20-2025, 06:23 PM
A930Rocket's Avatar
It's as strong as the paint bond on both sides….
^^^ This.
Can you use some 40-60 grit on a sander to rough it up?
Old 10-20-2025, 06:30 PM
If you bought pre painted then I'm sure it's primer and tight bond lll will stick to it just fine. I'd use a pin nailer to hold it where you want it. If you don't have one a brad nailer will work but you'll be filling holes
Old 10-20-2025, 06:39 PM
Thanks folks!
Old 10-20-2025, 07:18 PM
Model Citizen
You could also mortise a 1/4" deep rabbet on the inside edge of the frame; that'll give two benefits; no raw plywood edge exposed, fresh wood to glue to.
Old 10-20-2025, 07:35 PM
Depending on what will this project be used for? I dislike gluing anything to painted surfaces. Small stuff or something that are not used to hold up any weight, then I would give it a go.
Old 10-20-2025, 07:48 PM
Glueing up to primer works. I wouldn't glue to top coat paint but this isn't the case. One other thing I would do after you've got your trim pieces glued and tacked is weight it down to a flat surface to allow the glued up trim to set and freeze that flimsy ¼" plywood flat over night. A "plywood press" and you'll have nice flat panels
Old 10-20-2025, 08:32 PM
Attic hatch access doors that will be hidden in the backs of closets behind clothes, so not visible, no weight to speak of.
Right, I've got weights and clamps pressing the doors.
Old 10-20-2025, 08:51 PM
I don't know how big your panels are but I've used my work table for smaller panels with a larger sheet of plywood on top and a car battery or two on top of that. I've pressed larger panels on the shop slab and rolled the front wheel of my motorcycle right in the middle
Old 10-20-2025, 09:03 PM
Assume it will be painted upon finished? If so, use screws to keep it from coming apart and glues panels like if you had a press. Heat will cause glue to de-laminate some. Use your pinner, glue and screw. Fill screw holes with bondo and paint to make it look pretty.
Speaking of press. You want a heavy duty press? It can glue pieces up to about 3" wide. Its custom make for one job we did long ago. 4" square 1/4" thick steel tubing with 4 clamps on each press. I have 4 of them. Shipping will kill. About 60070 lbs each. Works great
Old 10-20-2025, 09:57 PM
^ if you were going to use screws wouldn't you screw from the back and not bondo? Just glueing is enough anyway. Is your trim wide enough to baby biscuit the miters? Got a biscuit muncher?
Old 10-20-2025, 10:21 PM
I honestly didn't fully read the whole thing. Assuming he's gluing 1/4" plywood to the face and not the back? Screws wouldn't hold from the back
Old 10-20-2025, 10:24 PM
Ok, just read again. Steve is gluing plywood to the frame so it appears like a shaker door or frame and panel door. Screw and glue through the 1/4" plywood and be done wit it. None of the screws will be seen
Old 10-20-2025, 10:26 PM
We use screws for drawer fronts because they're being pulled on but not for delicate mitered trim.
Brutal
Old 10-21-2025, 08:38 AM
