A930Rocket's Avatar
Air horn wiring question
*** This isn’t my truck or horn, but a question asked on the F150 forum.***
Does the wiring look right on this diagram for the application?
It seems like the red and black wires are mixed up, connecting to the battery. The horn button completes the circuit on the negative side. What does the red wire from the horn to the battery do?
How would you wire this?
I’m thinking it needs to be wired like this, but I’m no EE.
Old 11-04-2025, 05:47 PM
Usually black is used for ground and red for positive 12V but they decided (and wired their product) differently.
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 11-05-2025, 04:46 AM
D idn't E arn I t
RANDY P's Avatar
A fuse, and it looks like the compressor would run with key off.
I would not try that with a compressor unless you want a dead battery. Try a relay on the +12 tied to a key switch cutting off battery while off. If the system isn't leaking the horn should still work with key off, for awhile.
AOC/Hogg 2028
Old 11-05-2025, 05:54 AM
A930Rocket's Avatar
A relay on switched power to the positive side is a good idea.
Is picture 1 or picture 2 the better way to wire it?
Old 11-05-2025, 06:11 AM
I always put the fuses close to the positive battery terminal. Like right at the terminal.
And, I generally use red wire on the positive side, black on the negative.
Old 11-05-2025, 06:28 AM
Counterclockwise?
I had this problem years ago and couldn't figure out why the horn stayed on. I believe the first diagram is correct.
Rod
1986 Carrera
2001 996TT
Old 11-05-2025, 06:32 AM
Zeke's Avatar
It will work either way, electrical current don't care. But a fuse on the negative wire leaves the circuit hot to seek any form of short (ground) until something burns up. I vote #2.
Old 11-05-2025, 06:38 AM
A930Rocket's Avatar
Here’s what I’m thinking now. This will add a fuse of both positive wires and a switched relay, so the compressor doesn’t run all the time.
Old 11-05-2025, 07:49 AM
Counterclockwise?
Is this a train horn?
They are nasty!
Rod
1986 Carrera
2001 996TT
Old 11-05-2025, 09:29 AM
Zeke's Avatar
Train Air Horn
^^^ Could be, huh?
Old 11-05-2025, 12:53 PM
The friend I partnered with in the Plymouth Trouble Shooting contest had a set of chimes off a diesel locomotive in his Scout.
Scott
'78 SC mit Sportomatic - Sold
Old 11-05-2025, 01:07 PM
D idn't E arn I t
RANDY P's Avatar
Picture #2. Conventional and someone isn't gonna mistake it for a hot lead.
AOC/Hogg 2028
Old 11-05-2025, 01:08 PM
A930Rocket's Avatar
Not my truck. Not my horns.
I just thought it was an interesting question how to wire it.
Old 11-05-2025, 04:47 PM
