I could never be a plumber
Yech!
The bathroom in our "new" house has two sinks and the drains were running slow in both of them. I don't like dealing with gunky drains when it's MY gunk but ..... ![]() This came out of the right side sink. The PO's wife was blonde, so now I know which sink she used - not that I give a *****.
It is pretty foul. My wife has really thick horse hair and gets a drain wookie every 6 months or so. I created a wire tool that will remove the wookie most days without having to disassemble the whole thing. The last one was the size of a mouse!
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
A larger tie wrap chucked in a drill will clear out sink traps.
^^^ That stopper is nasty. I'd toss it in favor of a new one. But if the seals still work and you can stand the thing, I guess soak it in dishwasher detergent for a while and hose it off. Out in the yard. |
Could I ask you to take a picture of it once it's cleaned up?
I don't understand how it works. Seems like it's a self clogging drain with all the hardware hanging off what ever it is you're holding in your hand. Thanks for the idea on the drain clearing with a tie wrap Zeke, I'll have to give that a try as I now have some really big tie wraps courtesy of a friend.
Scott '78 SC mit Sportomatic - Sold |
Awoke this am to no heat. Crawled in crawlspace to furnace and there was an honest flood. A stupid copper PEX T in a line above the ductwork had corroded and failed, spraying water into the flexduct, which eventually filled the plenum and tripped the pressure switch. So had both a furnace and plumbing fix today. Did the plumbing myself, furnace guy checked out furnace ok and we drilled a hole in plenum to drain. Fun fun fun.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
You do not have permissi
That looks like a nice brass stopper which will last forever.
Meanwhile other things are still happening. |
Kantry Member
A plumber once told me his boss had three things he wanted him to learn:
Payday was Friday Sh...stuff flows down hill. Don't lick your fingers. ![]() For hair in the drain, I fashioned a hook from a heavy duty paperclip. With two women in the house, it gets a work out from time to time.
Best Les My train of thought has been replaced by a bumper car. Last edited by oldE; 11-28-2025 at 11:33 AM.. |
That's nothing! There's a reason plumbers get hepatitis vaccine shots!!!
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
That's a common finger tap drain pop up. Clean if you like, if not buy a new one. Nothing to them but they often get stuck due to gunk. We have the same thing at our house and my wife has shoulder length hair but they come off like if we have a golden retriever. She seems to take care of it once every blue moon with her 99 cent hair removal tool https://www.homedepot.com/p/HDX-20-in-Hair-Snake-90830/324601746?source=shoppingads&locale=en-US. It get tossed it after removal.
When I have nothing better to do, I take that damn thing outside and spray it off with the hose and dunk it in vinegar for 30 min, brush it off with a tooth brush (use your wife's and make sure you put it back ), hose it off. Use plumber grease or silicon grease in the moving parts. it keeps it functioning properly and little gunk will stick to it making the next cleaning super easy.
I have some nitrile gloves for that kind of maintenance….
dolor et pavor Copyright Last edited by Arizona_928; 11-28-2025 at 12:55 PM.. |
Story about my long time plumber. I used his company's plumbing service years ago when I was starting out. He was itchy to make some extra money on the weekend moonlighting. OK, fine and seems to be a upstanding guy. After few years, he was completely on his own running his plumbing business.
One time, I asked his helper about the condition of a toilet drain. It looked pretty bad with all debris from demo. Young guy, had a disgusted look on his face and I agree, it was a bit disgusting because of the was wax ring and gunk. I screamed for Rick to come and have a look so we can decide if it needed to be changed out for our client. He said to his guy, why didn't you look and see. He then proceeded to show him how it done. He takes his hand, no glove, sticks it down into the toilet drain, pass the flange and started to tap on it and feel for rust in the elbow. After that, he removed the sub-floor and took a look at the condition from down below. Turn to me and said, its all good and it will last for many more years to come. Then look at his guy and said,"next time you will need to do this for him". I couldn't hold back my laughter. Thank goodness I don't have to do this or be near them. Ever since, I never shook his hand again and usually jsut left a check on the hood of his truck. Told my guys to never, ever borrow his tools and if they do, wash up well with acid for three hours. |
We have a below grade toilet, and a septic system.
When the rugrats were smaller there was a few occasions when wipes were flushed. The problem with below grade toilets is that as a low point they preferentially fill if there’s a blockage to the main line, and then they try to pump stuff back u to same.. When it’s blocked this pressurizes the system. Pulling the inspection cover in the U to snake - and after the first $500 bill to do this, I bought a powered snake - is really really unpleasant. |
One of my rental is on a hill side with a sump. One of my guys and I installed the pump and did all the concrete work. I only work on my own stuff and only if it brand new. I knew going in that I must purchase a reliable, domestic pump and not some cheap import. I would hate to have to be the guy to replace that pump in that standing sewage water. Its nasty.
If you think that's bad, ever see those guys that work commercial buildings? Blockage is in the basement normally hanging above in a parking lot. Once unclogged all that siht gushes out under a lot pressureand they have to clean it.
That or in foreign developing or 3rd world countries like Indoa. They send some poor skinny dude in the city sewer through a manhole with no shirt, no glove or any protection and the worst part, no real tool to clean a block age. Let me see if I can find that video |
Sad and this isn't really about sewer worker. Just nasty They have little girls born into a lower cast cleaning a public outhouse in some remote village, no gloves but by hand a a few towel. I wakeup daily knowing how good we have it here. |
These gloves at Ace are worth their weight in gold. They are even powder coating stripper resistant, the stripper I use, one dot on nitrile destroys the glove in seconds and then will burn your skin, killing a layer that slowly sloughs off for new baby tender skin underneath. Get a pair. I'd pay $25 if I had to without a thought.
Soft Scrub Neoprene Cleaning Gloves
Tru6 Restoration & Design |
They sell plastic sticks with barbs on them for cleaning the drain.
They are about 2 foot long and cheap. I've seen them at Menards.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 11-28-2025 at 02:20 PM.. |
Model Citizen
"Follow my teachings or you'll come back in the afterlife as a declogger in the sewers of Bangladesh - for eternity!"
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Edministrator
They get to give a little back, though.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
I now have a plumber on speed-dial ... "charge it"!
I thought about just buying a $500 beast to unclog my parents' instead ... nah... I'll continue to call Ronnie ... nights, weekends, holidaze ... and he lives clo$er ![]() Worth it ![]() I have learned from my recent efforts ... just call "the man"... the hard way. Last edited by KFC911; 11-28-2025 at 03:24 PM.. |
