suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Refrigeration unit removal
Hello and Help!
I'm renting a property that unfortunately contains an old 1930's wooden refrigeration unit. THe unit (refrigerator) is approximately 9X7 in size.
My question is this, how do I dispose of the unit, and does the wooden revfrigeration box have coolant lines running through it (the walls/floor) I've called 12 companies and all of them suggest calling the borough to make arrangements to remove it. THis could cost thousands of dollars that I don't want to spend.
Thanks,
Frank B
My car is naughty
Old 07-07-2004, 11:42 AM
Most power (utility) companies will remove your old refrigerator and/or freezer for free. They don't wan't inefficient technology to get passed on. In my area they also give a $50 savings bond to boot.
I'd give them a call and see if they can help or make a recommendation.
Warren & Ron, may you rest in Peace.
Old 07-07-2004, 12:14 PM
Wow. I wonder if that is old enough to be using ammonia as a refrigerant?
Bob S. former owner of a 1984 silver 944
Old 07-07-2004, 03:07 PM
Stay away from my Member
campbellcj's Avatar
Same situation in our office. There is a GIANT A/C unit from an old-school early 80's computer room. We have given up hope that it can be economically removed as walls & windows etc would likely have to be pulled out in order to get a crane in place...
Soo....maybe hang a blanket over it?
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 07-07-2004, 11:21 PM
suck my tail pipe
Frank B's Avatar
HI Guys,
Ammonia? Holy "S" ! THere are water lines running to and from the unit. I've called my borough codes enforcement officer and he said remove it and just throw it away. He offered no advice at all. I guess I'm glad about that. THe walls and front can be taken down I'd guess, and the ceiling also. The back of the unit is blocking a door that would be accessing the rear entrance of my shop,which is actually the side door, although there is a rear door in use now. I'm stumped, I guess I should just have someone cut it out and bring it to a dump site, after all it is just a huge wooden box. Any other thoughts?
My car is naughty
Old 07-08-2004, 05:02 AM
