Anybody taken an airbag steering wheel off?
I think the bushing in my Avalon sterring column is toast. There seems to be a little movement followed with a knocking noise. It apears to isolated in the column, so I want to take a look, but never removed a wheel with an airbag. How do you take of the "skin" that covers it, and the airbag itself?
TIA!
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
The airbag should pop off, and then you can remove the wheel.
It's actually very common for thieves to steal airbags out of cars; they end up replacing those in salvage-title cars.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Usually, the "skin" and the airbag come off together. Probably held in by a couple of screws from behind the steering wheel. Just make sure you pull the airbag fuse before messing around.
On my Chevy truck, I pull the airbag fuse, pop the two catch levers under the airbag, and unplug the wires under the bag. I would imagine a theif wouldn't bother with the fuse and could have a bag off in about 10 seconds.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Ok, thanks guys! I am a little paranoid so removing the fuse is a good idea.
Banned
please
Make sure you take the fuse out esp before you reconect it. i watched one of these things blow 4 tires 20ft in the air once. |
T o be safe, couldn't you simply remove the negative battery cable prior to working, just in case you accidentlly pulled the "wrong fuse"?
Bob S. former owner of a 1984 silver 944 |
MoneyGuy1 is on the money.
Remove the ground (negative) cable from the battery and wait about 3 minutes for any SRS capacitors to bleed off, then remove the steering wheel. If you don't remove power from the system, the air bag might deploy ... somehow. Sherwood |
Rule to remember:
"Even if it is only remotely possible that something bad will happen, odds are it will" Another rule (created by my wife) concerning Porsche cars and repairs: "If you can see it, you can't reach it. If you can reach it, you can't see it". (after watching me for years)
Not as it seems
money,, your wife is pretty sharp with that last bit of word smithing....
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I'm a lucky, lucky guy......She is my eyes for those parts I cannot see.
