GWB underage sex scandal
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Super Moderator
Lookin' good Thom. Are you going to seal the floor too?
Occam's Razor
Very nice Thom. Where's the air compressor? Did you pipe in air drops? Also, what is the reasoning behind the copper sheeting on that one section near the vice? I used a piece of 1/4" plate for my welding table, but I have to hit it with a flapper wheel every so often because of the rust. The stainless looks like a better material of construction.
Craig '82 930, '16 Ram, '17 F150 |
Feelin' Solexy
Copper because of conductivity perhaps?
Great looking setup, I'm going to build myself one when I grow up!
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Semper drive!
GWB had sex when he was underage????? Oh, the humanity!!!!
Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
The copper section is where I'll do my welding on small projects, and the copper sheet is so the welding spatter doesn't stick; it will glob onto the stainless.
This weekend I'll have some thin strips cut to cover the 2x4 facing of the bench, just for the bling factor. The air compressor is outside in it's own sound-insulated shed, and the supply line runs underground and into the side of the shop. This cools the air substantially; so much that I had to install an auto drain on the water trap. If you look closely in the 4th picture you can see one of the air drops; there's another right in front of the lift, below the hose reel, and another by the door. More pix @ http://66.34.72.138/garage/updates/index.html
Occam's Razor
Nice! So you trap out the water then filter it just as it enters the shop and before it goes to the drops.
You've given me some good ideas. Now I have to go home and redo my whole shop. Thanks for that. Why couldn't you have just stayed on message and posted pics of W and some teen-aged skank?
Nice! I just feel like I had sex with... ehemmm. Wish I had room to build a *****in garage like that. Some day.
'95 993 C4 Cabriolet Bunch of motorcycles |
Spray the inside of that van with Luminol. Voila, a Jackson Pollock painting in scandal fluids.
Bob S. '87 911 ("Hardtop" per neighbor) |
Yeah, I'm green with envy.
That looks beautiful. I ought to post pictures of my little rat-box of a garage, with bits and pieces of car and engine stuffed in under it. I have to work in the driveway half the time, because there isn't enough room in the garage. Aargh! Good on ya.Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
