-   -   electronics question-not car related (http://forums.pelicanparts.com/off-topic-discussions/182600-electronics-question-not-car-related.html)
JTO 09-14-2004 03:05 PM
Can someone tell me whether the voltage generated by a microphone do any work? Can it light a diode for example without amplification?
Thanks,
Troy
cowtown 09-14-2004 03:23 PM
No - you'd need an op-amp/transistor circuit to amplify.
concentric 09-14-2004 03:32 PM
Colin hit the nail on the head. You could use a FET switch that would be triggered by an input signal, but you'd still need an amp to make the voltage needed to light the diode.
Jason
JTO 09-14-2004 03:57 PM
OK so there is too little current to get any work out of the signal from a microphone, correct?
thanks,
Troy
concentric 09-14-2004 04:04 PM
without the use of an amplifier circuit, yes.
Remember that the capsule vibration is being turned into the electrical impulse, not a lot of energy can be created by piece of foil ribbon or a foil diaphragm.
Build a small amplifier (lots of stuff on-line and in tech books) and it will work like a champ.
Jason
cowtown 09-14-2004 04:09 PM
If you want to do it yourself, check out the Forrest Mimms (sp?) books at Radio Shack. They are $5 or so, and have lots of building-block circuits like this. There's one that covers op-amp circuits.
JTO 09-14-2004 04:17 PM
Thanks Guys!
Troy
