TiVo Fans - popup ads
Just when you thought you could get away from commericals...
http://news.zdnet.com/2100-1040_22-5644197.html
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Ads, what ads?
I don't remember the last time I fast forwarded through a commerical. As long as they don't f*** with the 30 second skip, TIVO can do what they want.
Neil '73 911S targa Last edited by Neilk; 03-31-2005 at 12:55 PM.. |
- Skip
1972 911T 1972 911E "RSR" |
Doesn't seem to matter. It doesn't stop you from fast forwarding through the ad it just adds a little feature with a dohicky while you ff.
-The Mikester I heart Boobies |
What they're working on is exactly that - to put an ad in when you ff. That way they know they have your attention. Looks like they're testing this in various areas, and most likely they'll use it everywhere once they get the bugs worked out.
Skip,
You need to go here and get some of the codes. To enable the 30 seconds skip... Select-Play-Select-3-0-Select - Toggles 30 second skip mode. This turns the Skip to End button into a 30 second skip button. Have fun.
Neil '73 911S targa |
Senior Member
Neil,
Thanks much! Thom, We will figure out a way around it! I used to hate commercials, now I just FF the Tivo and get on with the program. Hey, how many people here have put an additional hard drive, or a larger on in their Tivo??? Getting ready to do it and hope for some input. JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Neil- That rules!
Many thanks... Skip
Joe,
I replaced the HD in my TIV, it's pretty easy to do. Go to this site and download the boot cd (MFS TOOLS 2) and follow the instructions for your particular setup/desire. Rather than spend $20 on a $2 piece of plastic, I just pulled my old hard drive and replaced it with a 160gb Seagate drive on which I copied ALL my old tv shows that I had saved. It took me about 30 minutes of actual work to get everything setup and about 2 or so hours to transfer all my shows from one drive to the next. Actually, now that I think about it, I didn't mount the second drive because I didn't want to wait to get the HD mounting bracket.
Senior Member
Neil,
I have the book Hacking Tivo, both 1 & 2 and they come with the CD. I booted it using the cd and "approved" the drive but just not sure it worked right. I have a series 2 box so assuming that it has only one HD inside and wanted to add a 160 gig second drive. Am VERY familiar with computers and the drive was formatted using NTFS (w2000) then did it using the CD so assume it was reformatted. Did you backup your orginal drive first and if so how? Work OK? Thanks for the help, need more room on my Tivo! Joe A
Senior Member
Appreciate the help!
Joe
Registered abUser
Tivo is going to relive the history of beta-max if they aren't careful. Being the best doesn't automatically guarantee you success.
Tivo has been in financial trouble since day one. Great product with true name recognition, but still a small market share a tons of hurdles to overcome. Sad...
