Detached Member
Hugh R's Avatar
Aston Martin Transmission Help
I know this isn't the forum, but the Aston Martin board isn't any help. Don't know why I'm posting here, other than I don't know where else to go with knowledgeable motor heads.
My DB4 trannie was making a lot of rumbling noise at 4000 rpm in any gear so I pulled it, and replaced the front and rear cages ball bearings. Everything else looked fine. Now, I can't get it to go into fourth gear on the bench. I might have switched a sycro, but I didn't mean to. So I tried changing syncro rings around no luck. Its driving me nuts.
Best of all, on reflection, if I'm getting a vibration at 4000 rpm (engine) I now realize its probably not the trannie, but an imbalance on the front damper or the flywheel/pressure plate.
I think it won't go into fourth because the syncro under rotation seems to be about 1/2 tooth off on being able to push the cluster over the synchro and onto the gear. Other gears work fine, including reverse.
Wayne, sorry for wasting bandwidth on this non-Porsche problem. But the Aston Martin forum is not very helpful.
Hugh
Old 04-09-2005, 09:54 PM
A Man of Wealth and Taste
tabs's Avatar
Press the RED BUTTON.....Ohhh that was the Bond car SORRY!
Copyright
"Some Observer"
Old 04-10-2005, 11:34 PM
