How Stuff Works - Light sabers
Chances are that you have seen a lightsaber at one time or another, whether on the evening news or down at the local cantina. Therefore you know that a lightsaber is an amazing and versatile device that is able to cut through nearly anything in a matter of milliseconds.
Have you ever wondered how these remarkable weapons work? Where does the energy come from, and how are they able to contain that energy in a rod-like column of glowing power? In this edition of HowStuffWorks, you will have a chance to look inside a lightsaber and discover the source of its incredible characteristics. Let's get started! http://www.howstuffworks.com/lightsaber.htm |
"There are two ends to any lightsaber -- one end has the belt ring, while the other end houses the blade arc tip and blade emitter. NEVER point the blade emitter of a lightsaber toward your own body. NEVER look down the "barrel" of a lightsaber, even if you are "sure" it is in safe mode. If you accidentally activate the lightsaber, serious injury could result. "
I bet Kalifornistan would be the first with light saber control laws, and light saber lock requirements... No concealed light sabers... no .50 cal lightsabers or 'assault' lightsabers.... |
:D Hilarious!
thanks Thom |
http://forums.pelicanparts.com/uploa...1115400081.jpg
Alternate uses: lighting cigarettes. Excellent. |
can i borrow someones? i got serious growth on my hedges. the old school two stroke gas powered hedger just aint cuttin it.
They are all great fun until some one loses an eye.
| All times are GMT -8. The time now is 11:16 AM. |
