Cabinet installation Gurus needed
I completely remodeled the kitchen in one of my condos and I have drawn a blank. How do you install the toe kick on the bottom of the cabinets without showing any screws? Only thing I can think is to glue it. Help me.:(
http://forums.pelicanparts.com/uploa...1116595083.jpg |
I use a brad nailer then a touch of color matched wood putty or a color stick. Actually with the brad nailer the holes are so small you really don't even need to fill them.
Construction adhesive. http://www.stickwithpl.com/projects/gen_construction.asp
I would also use a brad nailer.
However, good old Elmer's wood glue does an awesome job itself. |
I've used a Paslode angled finish nailer followed by a small dab of putty...
Terry,
You can probably find hardware for this application at a cabinet builders supply house. Hafele makes at least one design of snap-on connectors that would work. Ed |
i would nail high enough so that you cant see th nail and nail low enough so that the shoe molding covers the lower nail.
| All times are GMT -8. The time now is 04:14 AM. |
