-   -   Airbus A380 Issue (http://forums.pelicanparts.com/off-topic-discussions/234230-airbus-a380-issue.html)
singpilot 08-03-2005 10:41 AM
Pete;
Most of the heavies have specified taxi route and gates at every airport to take this into account. Every pilot's IOE (Initial Operating Experience) and Airport Familiarization exercise takes these situations into account. Some taxiways are not available because of wingspan or weight.
The scariest thing these days is a divert of some kind. To an airport that you are not familiar with.
There was a lot of discussion along these lines when the BA 747 continued to England after an engine failure on climbout from Los Angeles. If they had made it without incident, no one outside the industry would have even learned of it. Trouble was, they had to declare a fuel emergency and land in Ireland after not taking all the 3 engine performance charts into account.
The new A380 is rewriting some of these rules, as well as coming up with the list of airports that will be served. They had to do a bunch of wing redesign to compensate for the wingspan max limit imposed by physical limitations at the airports they wanted to serve. That is a fairly small list of intended airports for this behemoth.
dhoward 08-03-2005 10:44 AM
Kinda like building 10 foot wide cars for use on 8 foot wide highways.
Oops!
Tim Hancock 08-03-2005 10:50 AM
Tight TURN=not so bad. PIVOT=not so good.
Drago 08-03-2005 12:11 PM
Being that the same thing happened on the 747 back when it was being developed, I have a hard time trying to figure out why Airbus thought they could get away without steerable trucks.
singpilot 08-03-2005 12:20 PM
I think it goes back to the idea that the inventors of manned flight (the French) could not possibly have anything to learn from someone else's experience.
The Concorde crash reminded us all of that. Some things never change.
Tim Hancock 08-03-2005 12:32 PM
I guess if the worst thing about an Air bus is that some moron tug driver might skuff the tires and leave skid marks on the tarmac when he gets confused and tries to turn it around in a tight place, it will be in good shape.
My guess is that this will not end up being the worst thing to ever come out of operating an Air bus!
scottmandue 08-03-2005 01:13 PM
B-52
http://www.hq.nasa.gov/office/pao/History/SP-468/ch12-3.htm
304065 08-03-2005 02:17 PM
Yep, the BUFF had a castering gear.
So did the. . . Cessna 195! (optional)
Years of taildragger experience teaches you to land in the exact same direction the airplane is flying. With the castering gear you fly the airplane onto the runway WITH the crosswind crab held in.
Goes against every intuition but it works.
beepbeep 08-04-2005 01:22 AM
1. Concorde run over a metal strip that separated from american airliner, which destroyed one of tires, which brought down the plane. Concorde has very high TO speed and has much smaller TO envelope.
2. Pics posted above are from gear overstress-tests. Of course, people who don't like Airbus will forget that and use it as a proof of faulty design.
MFAFF 08-04-2005 05:55 AM
Sing,
If you are refering to the BA flight that took off from LAX destined for LHR that had a engine out from shortly after t/o it landed at Manchester, not in Ireland and the issue, from the thread attahced (its bit long) was more to do with a potential fuel transfer problem that became an issue once the crossing had been completed. The crew appears to have taken into account the 'new configuration' and adapted to it. The issue which caused an ealry landing amy or may not have been directly related.
Bear in mind its only from open sources such as this that this conclusion has been reached.
http://www.pprune.org/forums/showthread.php?threadid=173143
As for the A380 landing gear much has been said on this thread http://www.pprune.org/forums/showthread.php?threadid=182113 covers the reasons for these images.
It appears to have been a test of the worse possible ( in hte testers imagination) event that could occur on the ramp.
It was a deliberate mishandling of the aircraft at max load etc etc etc.....
Again the impression given is that the design is somehow at fault.
The A380 is designed to operate within the same parameters as the B747-400.....as these standards were set along time ago and ahve proven very robust.
So turning radii and wheel loadings are within the range acceptable for current airfield specifications.
The real issue however is that the many jetway layouts are already at maximum extension with a 747. The A380 takes it over the top creating a number of problems for existing field operators. However the standards for terminals have been resivsed to accommodate the A380 (and at the time longer winged B777 versions). This means new international terminals shoul be able to accommodate the A380 if they respect these standards.
304065 08-04-2005 06:19 AM
MFAFF,
That was an interesting thread. It does indicate that the 380 has four main gear, two in the fuselage and two under the wings, the gear in the wings being slighty forward of the gear in the body. As such, the aircraft cannot be turned without some of the wheels scrubbing. The 747 compensates for this by steering the body gear to minimize scrub.
It goes on further to state that the maximum steering angle with a towbar will be limited to 60 degrees in operations, but has been tested as high as 72 degrees. I can't locate the spec for a 747, but I do know that the smaller jets have a much higher steering angle.
It does appear, however, that that damage was done with the aircraft well above MGTOW.
Why do you think they didn't include a steering feature? Weight? Complexity?
"Landing Check! Mix Air Trim Pump Lights Brakes Ready to Come Aboard!" Sure could use a castering gear HERE!
http://forums.pelicanparts.com/uploa...1096979531.jpg
beepbeep 08-04-2005 06:40 AM
A380 tyres withstand extreme handling tests: Airbus
London (15Jul05, 12:01 GMT, 174 words)
Airbus is claiming that the undercarriage and tyres on its A380 aircraft have performed as expected after being subjected to extreme ground-handling tests last month.
Images show that the tests resulted in deformation and damage to the aircraft’s Michelin tyres but that they performed “at and above” expected levels during the abusive ground-handling tests on 25 June.
The A380 main undercarriage comprises two four-wheel under-wing bogies and, behind them, two six-wheel fuselage-mounted bogies. The rear axle of the six-wheel bogie is normally steerable during push-back and taxiing.
But unless electrical power is supplied to the aircraft during towing - by the aircraft or from generators on the tow-tractor - the axle remains locked.
Airbus states that the undercarriage tests were designed to take the undercarriage and tyres “way beyond the limit of normal operations” and adds: “[The tests] were the equivalent of the structural static airframe tests to destruction.
“Although these tests were designed to test up to maximum deformation and beyond, the gear did exactly what it is supposed to do.”
IROC 08-04-2005 06:45 AM
Well, I'm glad we finally got to the end of this. Sorry to stir the pot somewhat, but I obviously was the recipient of an email (from a fellow Boeing employee) that mis-represented these pictures.
They were neat pictures, though. Maybe to make up for it I will post some pictures of when they tested the 777 wings to failure. :>)
Mike
Drago 08-04-2005 10:03 AM
Originally posted by IROC
....Maybe to make up for it I will post some pictures of when they tested the 777 wings to failure.
There is a video of that test out there somewhere. Very impressive...and the wing failed at something like 5% over the predicted failure load.
IROC 08-04-2005 10:10 AM
Yeah, it was amazing. I think the wingtips withstood something like 24 feet (?) of vertical displacement before failure.
Mike
MFAFF 08-04-2005 10:13 AM
IROC,
Stirring is no bad thing, provide you know how and when to ackonwledge the facts arriving on the scene.....
The reality of the steerable gear is complex.
The B-52 has it because it is 'bicycle' type u/c and is flown onto the runway, not flared as other aircraft...thus you cannot fly crabbed on approach and kick her straight before th emains touch....all 4 trucks are supposed to hit at the same time so no pivot action....the trucks are 'crabbed' to allow axial (relative wind' approached to e maintained all the way to t/d...
The 747 has them solely to allow confirmed area ops....remember the 747 was a factor of 1.7 larger in wingspan etc et cat the time to say nothing of pax numbers. Airports were not even close to being able to cope. The steerable u/c was a way of enabling 747s to use many more airports...the gear was also a useful left over of the C-X programme (later C-5Galaxy) which imposed very strict truning radii etc in 'tactical' situations. Another example of Boeing's resourcefulness.
The A380 is not being born at the same time. WEight and seat mile economics are the primary driver....so any weight (she's already a fat bird) that can be saved is a good thing....IS the scrubbing going to significantly affect tyre life compared to a heavy landing? I don't know but I imagine the trade off has been considered...
IROC 08-04-2005 10:19 AM
Originally posted by MFAFF
...The steerable u/c was a way of enabling 747s to use many more airports...the gear was also a useful left over of the C-X programme (later C-5Galaxy) which imposed very strict truning radii etc in 'tactical' situations. Another example of Boeing's resourcefulness.
Or some would say "stubbornness". The way I heard the story told, the government specificied a high wing design for the C-X program and Boeing just knew they were smarter and offered what is now the 747 for the competition...and lost.
Of course, maybe that's the way I heard the story because I am old McDonnell Douglas... :>)
Mike
Drago 08-04-2005 10:22 AM
Geeze, I thought we finally got rid of all you guys... :)
IROC 08-04-2005 10:25 AM
Never!!!!!!! :>)
singpilot 08-04-2005 11:04 AM
When I pointed out that the pics had the Airbus copyright logo in the corners, I suspected that there had to be more to that story. Why else would Airbus release the pics?
When I heard the HF radio calls from the BA flight (I was over the North Atlantic that night), the destination was changed to Shannon. There was a long (especially for HF) discussion with the Shanwick radio operators relaying from BA ops, requests for actual fuel remaining, and WHERE the fuel was. Your post makes that make sense. When they went to VHF, we could no longer hear (we were westbound), and I assumed they went to Ireland. The HF atmospherics that night were bad for talking eastbound, our AFIS SATCOM was even affected, and we had to relay our position reports thru Gander from 20 west (early). The BA flight was similarly affected. Thanks for the reference.
And I am also an old Douglas guy.
P.S. Thanks MFAFF, I had never seen the PPrune site.
